2013-10-16 | build: fix cp destination in sample script | Max Krummenacher | |
2013-10-16 | build: add a sample script for setting up the environment | Max Krummenacher | |
2013-10-16 | local.conf: set sensible defaults | Max Krummenacher | |
2013-10-16 | bblayers: remove unneeded layer | Max Krummenacher | |
2013-10-16 | bblayers.conf: change path to meta-lxde | Max Krummenacher | |
2013-10-10 | conf: update sample configuration | Max Krummenacher | |
2013-09-22 | local.conf template: add inclusion of license information | Max Krummenacher | |
2012-10-18 | config changes due to oe-core update | Max Krummenacher | |
2012-08-15 | L4T R15, oe-core Image V2.0Beta1 | Max Krummenacher | |
2012-07-19 | build configuration files | Max Krummenacher | |
