path: root/conf
2014-10-06systemd: don't pull in systemd 216Max Krummenacher
meta-angstrom backported systemd 2.16 into daisy. Keep using 2.11 for now.
2014-08-04apalis-imx6.conf: specify the devicetree nameMax Krummenacher
2014-08-04machine.conf: xserver: make sure to use machine specificMax Krummenacher
If the package manager finds a version newer than the prefered-version that one gets installed. As we need a specific one for the tegras and for imx6 we change the 'epoch' to something very high.
2014-08-04machine.conf: unify MACHINE_FEATURESMax Krummenacher
unify the features between machines kernel26 is deprecated and unused apm does not make sense on ARM While at it remove some commented stuff
2014-06-12apalis-imx6: remove unneeded variableMax Krummenacher
2014-06-11virtual/kernel: set preferred unconditionalyMax Krummenacher
Be consistent with the other machine recipes Help the autobuilder setup
2014-04-04Revert "cortex-a5.inc: backport from openembedded-core dora branch"Max Krummenacher
File now provided by openembedded-core This reverts commit 592b1395c7cdff2125b5e42a7f9605749e625419.
2014-04-01machines: add colibri-vf, apalis-imx6Max Krummenacher
2014-04-01colibri-vf: use meta-fsl* layer for BSP filesMax Krummenacher
remove the files copied from meta-fsl* for Colibri-VF V2.1 move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra
2013-11-21Machine: remove Colibri VF50, now unified with VF61Max Krummenacher
2013-11-21Vybrid: add 'vf' to SOC_FAMILYMax Krummenacher
2013-10-16machines: T30 and VF50 consitstently use NEON and hard floatMax Krummenacher
- Colibri T30 and Apalis T30 changed to NEON - Colibri VF50 changed to hard float This makes packages built for T30 incompatible with Colibri T20 (but Colibri T20 packages can still be used on T30)
2013-10-14vybrid: backport from meta-fsl-arm master-nextMax Krummenacher
remove when moving to dora branch
2013-10-14cortex-a5.inc: backport from openembedded-core dora branchMax Krummenacher
revert when moving to dora
2013-10-10colibri-vf50: add the machine, kernel and u-bootMax Krummenacher
- also add the relevant configuration files
2012-10-18removed *~ backup files from git repoMax Krummenacher
2012-07-21removed unneeded apmd from machine featuresMax Krummenacher
2012-06-03Initial commitMax Krummenacher
