path: root/qt5-layer/recipes-qt/qt5/packagegroup-qt5.bb
2021-08-14layer: convert to new override syntaxMax Krummenacher
This is the result of automated script (0.9.3) conversion: +# meta-toradex-distro +vars = vars + ["preempt-rt","tdx","upstream"] +# meta-toradex-* machines +vars = vars + ["apalis-","colibri-","verdin-","tegra124"] +# meta-freescale +vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"] ../openembedded-core/scripts/contrib/convert-overrides.py . converting the metadata to use ":" as the override character instead of "_". Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-01-09qt5: do not require meta-qt5Max Krummenacher
Move all qt5 relevant stuff where it only gets parsed if meta-qt5 is available. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
