path: root/recipes-bsp/u-boot
2013-11-21u-boot: colibri-vf: use the unified u-boot 50/61Max Krummenacher
2013-11-21Machine: use the changed machinename colibri-vfMax Krummenacher
2013-10-23u-boot: update to latest git versionMax Krummenacher
2013-10-10colibri-vf50: add the machine, kernel and u-bootMax Krummenacher
- also add the relevant configuration files
2013-10-10u-boot-fw-utils: add bbappend to use the same u-boot sourcesMax Krummenacher
2013-10-07u-boot: clean up recipeMax Krummenacher
2013-09-22u-boot: don't build the examplesMax Krummenacher
- they do fail because they don't heed the private libgcc
2013-08-23u-boot: update to latest git versionMax Krummenacher
2013-06-26u-boot: update to latest git revisionMax Krummenacher
2013-03-04remove unused filesMax Krummenacher
2013-01-29u-boot: add Apalis-T30Max Krummenacher
- add Apalis-T30 - remove u-boot machine definition, this is also defined in the machine conf.
2013-01-22u-boot: update to latest on git.toradex.comMax Krummenacher
2012-12-31update u-boot and kernel git versionsMax Krummenacher
remove testfile
2012-12-18u-boot: remove all modification, they are moved to u-boot gitMax Krummenacher
2012-10-18u-boot: update to 16a9368a88a28252ea1daedc1df03ccc49ea5b22Max Krummenacher
2012-10-18removed *~ backup files from git repoMax Krummenacher
2012-10-18u-boot: update to a1ab5236759b1cd6fae427517d44d7be90b02c07Max Krummenacher
2012-08-23Use kernel and u-boot from git.toradex.comMax Krummenacher
Move changes done to other repos into .bbappends in meta-toradex
2012-08-15L4T R15, oe-core Image V2.0Beta1Max Krummenacher
2012-07-21pull u-boot unified for vibrante and l4t and the corresponding l4t kernelMax Krummenacher
2012-06-12- mklibs is no longer downloadable in the 0.1.33 version, upgrade to next ↵Max Krummenacher
version
2012-06-03u-boot base from meta instead of a copy from meta-tiMax Krummenacher
fix u-boot to no longer fail at runtime, (write beyond array)
2012-06-03Initial commitMax Krummenacher
