index
meta-toradex-demos.git
dunfell-5.x.y
jethro
jethro-next
kirkstone-6.x.y
master
morty
morty-next
rocko
rocko-next
thud
thud-next
zeus
Toradex BSP layer, recipes for the demo images
Marcel Ziswiler
summary
refs
log
tree
commit
diff
log msg
author
committer
range
path:
root
recipes-bsp
Age
Commit message (
Collapse
Author
2013-01-22
u-boot: update to latest on git.toradex.com
Max Krummenacher
2012-12-31
update u-boot and kernel git versions
Max Krummenacher
remove testfile
2012-12-18
u-boot: remove all modification, they are moved to u-boot git
Max Krummenacher
2012-10-18
u-boot: update to 16a9368a88a28252ea1daedc1df03ccc49ea5b22
Max Krummenacher
2012-10-18
removed *~ backup files from git repo
Max Krummenacher
2012-10-18
u-boot: update to a1ab5236759b1cd6fae427517d44d7be90b02c07
Max Krummenacher
2012-08-23
Use kernel and u-boot from git.toradex.com
Max Krummenacher
Move changes done to other repos into .bbappends in meta-toradex
2012-08-15
L4T R15, oe-core Image V2.0Beta1
Max Krummenacher
2012-07-21
pull u-boot unified for vibrante and l4t and the corresponding l4t kernel
Max Krummenacher
2012-06-12
- mklibs is no longer downloadable in the 0.1.33 version, upgrade to next ↵
Max Krummenacher
version
2012-06-03
u-boot base from meta instead of a copy from meta-ti
Max Krummenacher
fix u-boot to no longer fail at runtime, (write beyond array)
2012-06-03
Initial commit
Max Krummenacher
