2013-10-17 | midori: add inital bookmarks and homepage | Max Krummenacher | |
2013-09-22 | wpa-supplicant: workaround missing service file | Max Krummenacher | |
2013-09-22 | openssh: follow update of recipe with bbappend | Max Krummenacher | |
2013-09-22 | systemd: adapt to new systemd handling | Max Krummenacher | |
with the move from meta-openembedded to oe-core some things have changed, e.g. the config files have to explicitly installed | |||
2013-09-22 | remove obsolete files | Max Krummenacher | |
2013-09-22 | wpa-supplicant: don't install systemd service file | Max Krummenacher | |
- is already installed | |||
2013-09-22 | connman: add a unused .bb to silence a bbappend | Max Krummenacher | |
2013-09-22 | connman: bbappend updated to 1.12 | Max Krummenacher | |
2013-09-22 | connman: bbappend updated to 1.10 | Max Krummenacher | |
2013-07-26 | openssh: give the subpackages there own -dev, -dbg | Max Krummenacher | |
this allows a debug installation of dropbear with openssh-scp, openssh-sftp and openssh-sftp-server | |||
2012-10-19 | connman.service: start the service only when the rootfs is not an NFS mount | Max Krummenacher | |
