2014-08-04 | openssh: do not use reverse DNS | Max Krummenacher | |
This gets rid of a long timeout when connecting in a network which does not provide reverse DNS. | |||
2014-08-04 | remove obsolete recipe and patch | Max Krummenacher | |
2014-08-04 | connman.service: adapt patch to new upstream version | Max Krummenacher | |
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-08-04 | Use generic bbappend files | Max Krummenacher | |
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it. | |||
2014-04-01 | openssh bbappend: update to match bb version | Max Krummenacher | |
2014-04-01 | midori bbappend: update to match bb version | Max Krummenacher | |
2014-04-01 | connman bbappend: update to match bb version | Max Krummenacher | |
2013-10-17 | midori: add inital bookmarks and homepage | Max Krummenacher | |
2013-09-22 | wpa-supplicant: workaround missing service file | Max Krummenacher | |
2013-09-22 | openssh: follow update of recipe with bbappend | Max Krummenacher | |
2013-09-22 | systemd: adapt to new systemd handling | Max Krummenacher | |
with the move from meta-openembedded to oe-core some things have changed, e.g. the config files have to explicitly installed | |||
2013-09-22 | remove obsolete files | Max Krummenacher | |
2013-09-22 | wpa-supplicant: don't install systemd service file | Max Krummenacher | |
- is already installed | |||
2013-09-22 | connman: add a unused .bb to silence a bbappend | Max Krummenacher | |
2013-09-22 | connman: bbappend updated to 1.12 | Max Krummenacher | |
2013-09-22 | connman: bbappend updated to 1.10 | Max Krummenacher | |
2013-07-26 | openssh: give the subpackages there own -dev, -dbg | Max Krummenacher | |
this allows a debug installation of dropbear with openssh-scp, openssh-sftp and openssh-sftp-server | |||
2012-10-19 | connman.service: start the service only when the rootfs is not an NFS mount | Max Krummenacher | |
