This reverts commit f06f9b397b0db891d902eefa54761b37e7d00ec6.
The fix is now applied in meta-openembedded.
The connman sources provide main.conf with all settings set to default.
Patch that file rather than providing the file in full from a maybe
outdated connman version.
Previously my morty build failed as follows:
| arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi
=hard --sysroot=/data/build/oe_core-V2.7/build/tmp-glibc/sysroots/apalis-tk1-mai
nline -Wall -DVER=1.6 -D_GNU_SOURCE -DHAVE_CLOCK_ADJTIME -DHAVE_POSIX_SPAWN -I/
lib/modules/4.8.13/build/usr/include -DHAVE_ONESTEP_SYNC -D_GNU_SOURCE -DHAVE_C
LOCK_ADJTIME -DHAVE_ONESTEP_SYNC -O2 -pipe -g -feliminate-unused-debug-types -fd
ebug-prefix-map=/data/build/oe_core-V2.7/build/tmp-glibc/work/armv7at2hf-neon-an
gstrom-linux-gnueabi/linuxptp/1.6-r0=/usr/src/debug/linuxptp/1.6-r0 -fdebug-pref
ix-map=/data/build/oe_core-V2.7/build/tmp-glibc/sysroots/x86_64-linux= -fdebug-p
refix-map=/data/build/oe_core-V2.7/build/tmp-glibc/sysroots/apalis-tk1-mainline=
-c -o msg.o msg.c
| {standard input}: Assembler messages:
| {standard input}:39: Error: bad instruction `bswapq r0'
| <builtin>: recipe for target 'msg.o' failed
| make: *** [msg.o] Error 1
As it tried using the kernel headers from my Fedora 23 build server
located at /lib/modules/4.8.13/build/usr/include.
Fix this by no longer calling the incdefs.sh shell script from the
makefile.
Remove the locally backported 6.8 version since bitbake anyway
use the newer 7.1 version from OpenEmbedded core.
This reverts commit 8d0349a08564a8044bad7f0f3ff0982e6d5a6aa2.
midori_*bb has been removed.
We've seen newer distros which incorrectly negotiate used cypher with the on
target openssh. Using 6.8 fixes that.
Connman gained support for USB gadget. The typical usecase is to use
USB gadget for tethering. In this use case the module would be the
device sharing the connection to the USB host connected to the module.
However, our typical use case in mind for RNDIS is a simple ethernet
connection between a development host and the module, hence no need
for tethering/routing. This however is not easily doable with connman,
since connman tries to have one connection online only. When enabling
USB gadget as a normal ethernet device, this typically leads to classic
ethernet not being configured since the USB RNDIS connection is already
up and running.
By blacklisting USB gadget, connman won't touch the device and we can
use other means of bringing up the network interface.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
This gets rid of a long timeout when connecting in a network
which does not provide reverse DNS.
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
with the move from meta-openembedded to oe-core some things have
changed, e.g. the config files have to explicitly installed
- is already installed
this allows a debug installation of dropbear with openssh-scp,
openssh-sftp and openssh-sftp-server
