path: root/recipes-core/base-files
2017-10-03fstab: add noatime to rootfs mount flagsStefan Agner
We rely on the init system to remount the root file system read-only, which makes the mount flags for the rootfs in fstab relevant. Since we run on flash drives minimize write cycles by disabling atime by by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-06-30profile: disable systemd color outputStefan Agner
By default systemd utilities use escape sequences to produce colored output. But systemd also uses less as a pager. The less command provided in the Toradex demo images is provided by BusyBox, which does not support color escape sequences. Disable colored output altogether. This makes output of journalctl much more readable. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11readline: follow moved inputrc into readlineMax Krummenacher
Commit 619d15b9a2c53eb8496c807f0f229f5cb192e9d7 in openembedded-core moves the inputrc file from the base-files to the readline recipe. Follow that move with our *.bbappend. This fixes <HOME>, <END> not working as expected on a serial console. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10profile: redirect resize output to /dev/nullMax Krummenacher
oe-core included resize in their profile too. Synchronize with the OE solution which already does the redirect. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10base-files: don't provide resolv.confMax Krummenacher
avoid clash with systemd provided resolv.conf Collected errors: * check_data_file_clashes: Package systemd wants to install file ../resolv.conf But that file is already provided by package base-files Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-28base-files: mv all files into recipes-core/base-filesMax Krummenacher
