path: root/recipes-core/glibc
2017-12-22glibc: no longer mess with memcpyMax Krummenacher
On the Tegras not using NEON for memcpy resulted in higher memory bandwidth. Let's verify this before forward porting the patch. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-10glibc bbappend: use version wildcardMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14glibc bbappend: follow version upgradeMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-11-10glibc_2.21: force memcpy_arm to improve memcpy performanceMax Krummenacher
A meta-toolchain build or a build which does not use the angstrom distro builds glibc_2.21 rather than glibc_linaro-2.20. The patch to not use the slower memcpy implemented for NEON does not apply cleanly for both versions of glibc. This adds a bbappend for glibc_2.21 forcing memcpy_arm.
2015-11-10glibc: apply bbappend only to linaro_2.20Max Krummenacher
0001-memcpy-don-t-use-optimized-for-VFP-NEON-versions.patch applies not to oe glibc_2.21
2015-10-28glibc: force memcpy_arm to improve memcpy performanceMax Krummenacher
