path: root/recipes-devtools
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2015-02-12mmc-utils: add recipe for chromiumos version thereofMarcel Ziswiler
Add a recipe for the Chromium OS version of the mmc-utils able to handle Extended CSD revision 1.7 of the latest MMC 5.0 specification. Some of the more interesting information thereof is the life time estimation and pre EOL information as follows: root@apalis-t30:~# mmc extcsd read /dev/mmcblk0 | \ grep -A 3 'Device life time estimation type A' Device life time estimation type A [DEVICE_LIFE_TIME_EST_TYP_A: 0x01] i.e. 0% - 10% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal
2014-08-04bbappends: remove the deprecated PRINC variableMax Krummenacher
2014-04-01systemd-compat-units: ensure that postinst is runMax Krummenacher
The combination of changes lead to the postinst scripts not beeing run at all.
2013-09-22python-numpy: bbappend deleted, now fixed in openembedded layerMax Krummenacher
2013-02-06python-numpy: backport fix of changed python-native pathMax Krummenacher
2012-06-12- mklibs is no longer downloadable in the 0.1.33 version, upgrade to next ↵Max Krummenacher
version
