path: root/recipes-devtools
2017-12-22mtd-utils: build natively for a 32-bit machineColibri-iMX7_LXDE-Image_2.8b1.64-20171229Colibri-iMX6_LXDE-Image_2.8b1.64-20171229Colibri-iMX6ULL_LXDE-Image_2.8b1.64-20171229Colibri-VF_LXDE-Image_2.8b1.64-20171229Colibri-T30_LXDE-Image_2.8b1.64-20171229Colibri-T20_LXDE-Image_2.8b1.64-20171229Apalis-iMX6_LXDE-Image_2.8b1.64-20171229Apalis-TK1_LXDE-Image_2.8b1.64-20171229Apalis-TK1-Mainline_LXDE-Image_2.8b1.64-20171229Apalis-T30_LXDE-Image_2.8b1.64-20171229Stefan Agner
We want to deploy mkfs.ubifs as part of the x86 downloader as most distros do not have a recent enough version. To be more universal we need it unconditionally in a 32-bit version. Moved from meta-toradex-bsp-common layer. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03opkg: add version wildcard to bbappendMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30run-postinsts_1.0.bbappend: fix FILESEXTRAPATHS_prependMax Krummenacher
Copy/paste error prevented the intended fix to get actually applied. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07meta-toradex-demo: clean-up whitespace useMax Krummenacher
2017-04-07run-postinsts: do not reload daemon configurationMax Krummenacher
2017-04-07opkg-configure: do not reload daemon configurationMax Krummenacher
2017-04-07mmc-utils-cos: add update-alternativeMax Krummenacher
With this both mmc-utils and mmc-utils-cos can be installed on a target, however mmc-utils will take precedence as it is not configured for an update-alternative. In that case the binary will only be available as mmc.mmc-utils-cos Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07mmc-utils-cos: update to latest and unify with mmc-utils_git.bbMax Krummenacher
Update to latest master of the Chromium OS port. A patch has been replaced by setting arch specific CFLAGS in mmc-utils in oe-core. Follow that change. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07mmc-utils-cos: rename recipe to be different from mmc-utilsMax Krummenacher
This allows to build either mmc-utils_git from openembedded or mmc-utils from the Chromium OS project. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-10python bbappend: use version wildcardMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10python_2.7.9.bbappend: fix d.getVar callMax Krummenacher
2016-09-29recipes: stop using base_containsMax Krummenacher
The base_contains function is deprecated and we ought to use bb.utils.contains instead. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29systemd-compat-units: mv all systemd bbappends under recipes-coreMax Krummenacher
2016-09-28mklibs-native: drop in favour of newer oe-core oneMax Krummenacher
2016-03-30python: add a PACKAGECONFIG for _tkinterMax Krummenacher
Currently _tkinter is only built when tcl/tk is available before the python do_configure task is built. Make this deterministic by providing a PACKAGECONFIG for it. If tkinter is in PACKAGECONFIG add the needed dependencies, if not force that tkinter is not built. Note that currently enabling tkinter does not work due to a cyclic dependency: 'python' depends on 'tk/tcl' depends on 'cracklib' depends on 'python' Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2015-02-12mmc-utils: add recipe for chromiumos version thereofMarcel Ziswiler
Add a recipe for the Chromium OS version of the mmc-utils able to handle Extended CSD revision 1.7 of the latest MMC 5.0 specification. Some of the more interesting information thereof is the life time estimation and pre EOL information as follows: root@apalis-t30:~# mmc extcsd read /dev/mmcblk0 | \ grep -A 3 'Device life time estimation type A' Device life time estimation type A [DEVICE_LIFE_TIME_EST_TYP_A: 0x01] i.e. 0% - 10% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal
2014-08-04bbappends: remove the deprecated PRINC variableMax Krummenacher
2014-04-01systemd-compat-units: ensure that postinst is runMax Krummenacher
The combination of changes lead to the postinst scripts not beeing run at all.
2013-09-22python-numpy: bbappend deleted, now fixed in openembedded layerMax Krummenacher
2013-02-06python-numpy: backport fix of changed python-native pathMax Krummenacher
2012-06-12- mklibs is no longer downloadable in the 0.1.33 version, upgrade to next ↵Max Krummenacher
version
