This reverts commit 9584b1a639c349b4b8023ddfed8e09efb5e5ae68.
The recipe is again available upstream
Without this many of the buttons are shown with an ugly place holder
image.
root@apalis-t30:~# gnome-disks
(gnome-disks:660): GNOME-Disks-WARNING **: Error lookup up icon media-playback-start-symbolic
libwnck3 was removed from oe-core but did not (yet) make it into
meta-openembedded. Pull in the patch here.
From: Alexander Kanavin <alexander.kanavin@linux.intel.com>
Date: Tue, 1 Nov 2016 17:28:21 +0200
Subject: [PATCH] libwnck3: add a recipe
It is no longer needed in oe-core.
Signed-off-by: Alexander Kanavin <alexander.kanavin@linux.intel.com>
Signed-off-by: Martin Jansa <Martin.Jansa@gmail.com>
| WARNING: gnome-disk-utility-3.21.3-r4 do_package: QA Issue: gnome-disk-utility: Files/directories were installed but not shipped in any package:
| /usr/share/appdata
| /usr/share/dbus-1
| /usr/share/appdata/org.gnome.DiskUtility.appdata.xml
| /usr/share/dbus-1/services
| /usr/share/dbus-1/services/org.gnome.DiskUtility.service
While at it, drop the nautilus extension package, that is no longer provided.
add libpwquality recipe from meta-qt5-extra.
This bbappend is required by packages built with meta-lxde.
Thus move it were it belongs.
compiling gvfs with samba support in dizzy does not only pull in smbclient
but the full samba package, i.e. 50MB+.
save space by not requiring smbclient.
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
libpcre splits into libpcre-*, use packages-dynamic so we can put them into an image
rename bbappend because coresponding bb does not exist
