path: root/recipes-gnome
2017-04-07meta-toradex-demo: clean-up whitespace useMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07gnome-disk-utility: depends on libxslt-native pkgconfig-native xmlto-nativeMax Krummenacher
2017-01-11gnome-disk-utility: add dependency on adwaita-icon-theme-symbolicMarcel Ziswiler
Without this many of the buttons are shown with an ugly place holder image. root@apalis-t30:~# gnome-disks (gnome-disks:660): GNOME-Disks-WARNING **: Error lookup up icon media-playback-start-symbolic Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-10libwnck3: add recipeMax Krummenacher
libwnck3 was removed from oe-core but did not (yet) make it into meta-openembedded. Pull in the patch here. From: Alexander Kanavin <alexander.kanavin@linux.intel.com> Date: Tue, 1 Nov 2016 17:28:21 +0200 Subject: [PATCH] libwnck3: add a recipe It is no longer needed in oe-core. Signed-off-by: Alexander Kanavin <alexander.kanavin@linux.intel.com> Signed-off-by: Martin Jansa <Martin.Jansa@gmail.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10gnome-disk-utility: package all installed filesMax Krummenacher
| WARNING: gnome-disk-utility-3.21.3-r4 do_package: QA Issue: gnome-disk-utility: Files/directories were installed but not shipped in any package: | /usr/share/appdata | /usr/share/dbus-1 | /usr/share/appdata/org.gnome.DiskUtility.appdata.xml | /usr/share/dbus-1/services | /usr/share/dbus-1/services/org.gnome.DiskUtility.service While at it, drop the nautilus extension package, that is no longer provided. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10gnome-disk-utility: add gtk3 versionMax Krummenacher
add libpwquality recipe from meta-qt5-extra. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10gvfs bbappend: use version wildcardMax Krummenacher
2016-09-28gdk-pixbuf_%.bbappend: delete, moved to meta-lxdeMax Krummenacher
This bbappend is required by packages built with meta-lxde. Thus move it were it belongs. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14gvfs_1.10.1.bbappend: don't build with gphotoMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14gvfs: use _remove to not build with sambaMax Krummenacher
2016-03-14gdk-pixbuf_%.bbappend: build for x11 dependend on DISTROFEATURESMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-05-18gvfs: add missing dependency on libgudevMax Krummenacher
2015-03-31gvfs: remove samba from PACKAGECONFIGMax Krummenacher
compiling gvfs with samba support in dizzy does not only pull in smbclient but the full samba package, i.e. 50MB+.
2014-08-04gvfs: don't use samba-client on vybridMax Krummenacher
save space by not requiring smbclient.
2014-08-04Use generic bbappend filesMax Krummenacher
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it.
2014-04-01gdk-pixbuf bbappend: update to match bb versionMax Krummenacher
2013-09-22gdk-pixbuf: change to the new X11DEPENDS for overrideMax Krummenacher
2013-09-22gdk-pixbuf: bbappend updated to 2.26.5Max Krummenacher
2013-06-26gdk-pixbuf: update icon cache on rootfs build timeMax Krummenacher
2012-10-18update in oe-core makes nautilus bbappend obsoleteMax Krummenacher
2012-08-27nautilus depends on gobject-introspection-nativeMax Krummenacher
libpcre splits into libpcre-*, use packages-dynamic so we can put them into an image rename bbappend because coresponding bb does not exist
2012-06-03Initial commitMax Krummenacher
