2015-05-18 | gvfs: add missing dependency on libgudev | Max Krummenacher | |
2015-03-31 | gvfs: remove samba from PACKAGECONFIG | Max Krummenacher | |
compiling gvfs with samba support in dizzy does not only pull in smbclient but the full samba package, i.e. 50MB+. | |||
2014-08-04 | gvfs: don't use samba-client on vybrid | Max Krummenacher | |
save space by not requiring smbclient. | |||
2014-08-04 | Use generic bbappend files | Max Krummenacher | |
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it. | |||
2014-04-01 | gdk-pixbuf bbappend: update to match bb version | Max Krummenacher | |
2013-09-22 | gdk-pixbuf: change to the new X11DEPENDS for override | Max Krummenacher | |
2013-09-22 | gdk-pixbuf: bbappend updated to 2.26.5 | Max Krummenacher | |
2013-06-26 | gdk-pixbuf: update icon cache on rootfs build time | Max Krummenacher | |
2012-10-18 | update in oe-core makes nautilus bbappend obsolete | Max Krummenacher | |
2012-08-27 | nautilus depends on gobject-introspection-native | Max Krummenacher | |
libpcre splits into libpcre-*, use packages-dynamic so we can put them into an image rename bbappend because coresponding bb does not exist | |||
2012-06-03 | Initial commit | Max Krummenacher | |
