The terminal output is not seen.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
Remove xinput-calibrator systemd service since autostart is done
using /etc/xdg/autostart/xinput_calibrator.desktop.
with the move from meta-openembedded to oe-core some things have
changed, e.g. the config files have to explicitly installed
- make the menuentry behave as the one time calibration on first boot
