path: root/recipes-graphics
2013-10-17evdev: backport V2.8.1 from doraMax Krummenacher
V2.7.3 crash when it receives multitouch events
2013-09-22graphviz: add recipeMax Krummenacher
2013-09-22systemd: adapt to new systemd handlingMax Krummenacher
with the move from meta-openembedded to oe-core some things have changed, e.g. the config files have to explicitly installed
2013-09-22xinput-calibrator: menuentry behaves as the first boot calibrationMax Krummenacher
- make the menuentry behave as the one time calibration on first boot
2013-09-22xinput-calibrator: bbappend updated to use git instead of versioned tarballMax Krummenacher
2013-05-15unclutter: add recipeMax Krummenacher
- Unclutter hides your X mouse cursor when you do not need it
2013-04-25scrot: add scrot recipe, commandline screen capture utilityMax Krummenacher
2012-12-17xinput-calibrator: make the menuentry behaviour as the one time calibration ↵Max Krummenacher
on first boot
2012-10-18xinput-calibrator: make this depending on lxdm, not no-display-managerMax Krummenacher
