2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-08-04 | Use generic bbappend files | Max Krummenacher | |
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it. | |||
2014-07-15 | vnc: add directvnc and tightvnc recipes | Marcel Ziswiler | |
Two popular VNC clients: - DirectVNC based on DirectFB (e.g. without X11) - TightVNC based on X11 (cherry picked from commit ef4113208de357a5b8accd7610f8bf3230125a59) | |||
2014-07-15 | xinput-calibrator.service: only start when lxdm is enabled | Max Krummenacher | |
If the xinput-calibrator.service is enabled but lxdm.service is disabled lxdm was started anyway because of the requires dependency. Replase Requires with Requisite to have xinput-calibrator.service fail instead. (cherry picked from commit e34e6361ecaaa8b148d438d517761bdd084d1a32) | |||
2014-04-03 | gpu-viv-bin-mx6q: add bbappend for no samples | Max Krummenacher | |
adds gpu-viv-bin-mx6q-libraries package which RDEPENDS only the libraries but not the samples. | |||
2013-10-17 | evdev: backport V2.8.1 from dora | Max Krummenacher | |
V2.7.3 crash when it receives multitouch events | |||
2013-09-22 | graphviz: add recipe | Max Krummenacher | |
2013-09-22 | systemd: adapt to new systemd handling | Max Krummenacher | |
with the move from meta-openembedded to oe-core some things have changed, e.g. the config files have to explicitly installed | |||
2013-09-22 | xinput-calibrator: menuentry behaves as the first boot calibration | Max Krummenacher | |
- make the menuentry behave as the one time calibration on first boot | |||
2013-09-22 | xinput-calibrator: bbappend updated to use git instead of versioned tarball | Max Krummenacher | |
2013-05-15 | unclutter: add recipe | Max Krummenacher | |
- Unclutter hides your X mouse cursor when you do not need it | |||
2013-04-25 | scrot: add scrot recipe, commandline screen capture utility | Max Krummenacher | |
2012-12-17 | xinput-calibrator: make the menuentry behaviour as the one time calibration ↵ | Max Krummenacher | |
on first boot | |||
2012-10-18 | xinput-calibrator: make this depending on lxdm, not no-display-manager | Max Krummenacher | |
