path: root/recipes-images/images/angstrom-lxde-image.bb
2018-03-22apalis-tk1-mainline: append summary indicating mainlineMarcel Ziswiler
Images for tk1 and tk1-mainline are currently indistinguishable especially when path to the image is long. For now simply append the description with " (Mainline)" should work. Let’s integrate this into our builds. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-22recipes: use oe.utils.conditional instead of deprecated base_conditionalMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-22angstrom-lxde-image: remove snapdMax Krummenacher
From feedback it looks like it is not widely used but it adds a lot to the final image as well as to build time as it relies on go and go-native. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-22images: add gstreamer1.0-plugins-good-multifileMarcel Ziswiler
Trying to store PNG files off our CSI Camera Module 5MP OV5640 on Apalis TK1 revealed the first few frames to be black resp. greenish. One way to overcome this is to save several images and just throw the first few away. In order to do so the multifilesink plug-in would be needed: gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,format={UYVY},width=640,height=480' ! videorate max-rate=10 ! videoconvert ! avenc_png ! multifilesink location=test%d.png Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-03-22images: remove adwaita-icon-theme from bad_recommendsMax Krummenacher
gpicview has an RDEPENDS on adwaita-icon-theme. Having adwaita-icon-theme in BAD_RECOMMENDS prevents gpicview from being installed. (Because gpicview itself is pulled in through a RRECOMMENDS) Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-22angstrom-lxde-image: colibri-imx6ull: add gpio-toolMax Krummenacher
2017-12-22images: follow upstream name change of libopencl-imxStefan Agner
The package libopencl-mx6 has been renamed to libopencl-imx. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22images: remove gstreamer plugins from DEPENDSMax Krummenacher
Depending on the module we use gstreamer in version 0.10 and 1.0. Building the plugins just to have the ipk packages without installing them now makes the recipe unreasonably complicated without adding real value. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22images: remove gstreamer ivorbis pluginMax Krummenacher
It is no longer built by default since oe-core commit 958926dd51d5e18ef983280a6e3b50fc8f33eb12: Even old hardware these days doesn't really need fixed-integer Vorbis decoding by default, so disable Tremor out of the box. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-11-27angstrom-lxde-image: remove gstreamer packages for colibri-imx6ullMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-10-04recipes-images: apalis-tk1: change gstomx packages nameColibri-iMX7_LXDE-Image_2.7b4-20171005Colibri-iMX6_LXDE-Image_2.7b4-20171005Colibri-VF_LXDE-Image_2.7b4-20171005Colibri-T30_LXDE-Image_2.7b4-20171005Colibri-T20_LXDE-Image_2.7b4-20171005Apalis-iMX6_LXDE-Image_2.7b4-20171005Apalis-TK1_LXDE-Image_2.7b4-20171007Apalis-TK1-Mainline_LXDE-Image_2.7b4-20171005Apalis-T30_LXDE-Image_2.7b4-20171005Dominik Sliwa
2017-10-03angstrom-lxde-image: colibri-imx6ull: don't deploy firefoxMax Krummenacher
With the space restricted NAND there is no space for a browser. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03images: add colibri-imx7-emmcStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03images: add colibri-imx6ullMax Krummenacher
2017-10-03tdx-image-fstype.inc: set PV to Toradex image versionStefan Agner
Use PV variable to define the image version. With that the Tezi image class can use OpenEmbedded variables to get the image version. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03recipes-images: apalis-tk1: deploy gstreamer-0.10Dominik Sliwa
Deploy gstreamer-0.10 with nvidia TK1 support plugins. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03angstrom-lxde-image: deploy ejectMax Krummenacher
The eject binary is used by the libudisk2. Without it e.g. pcmanfm shows an error message that eject could not be found. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30angstrom-lxde-image: add packagegroup-snapd to emmc modulesMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-04-10tdx-image-fstype.inc: renamed from trdx-image-fstype.incMarcel Ziswiler
2017-04-10tdx-extra.inc: renamed from trdx-extra.incMarcel Ziswiler
While at it also reflect changed name of tdx-nv-binaries. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-04-10tegra124m: deploy the gpio-toolMax Krummenacher
2017-04-07images: rename the image type nameMax Krummenacher
LXDE: LinuxImage -> LXDE-Image Qt4: LinuxImage-qt -> Qt4-X11-Image Qt4 embedded: LinuxImage-qte -> Qt4e-Image Qt5: LinuxImage-qt5 -> Qt5-X11-Image Console: LinuxConsoleImage -> Console-Image Additionaly the underscore in the machine name is replaced by a dash so that the image name is now comprised of 3 elements which themselfes do not contain an underscore but are separated by underscores. <machine>_<image type>_version e.g.: Apalis_iMX6_LinuxImageV2.7_20170327.tar.bz2 becomes Apalis-iMX6_LXDE-Image_2.7b2-20170327.tar.bz2 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07images: use the new version variablesMax Krummenacher
2017-01-11apalis-tk1-mainline: ship mesa-demosDominik Sliwa
2017-01-11images: remove SysV initscriptsStefan Agner
The package initscripts deploys some SysV initscripts which were still required for earlier systemd version. All services are now available through systemd, so this is not necessary anymore. It even leads to interference with systemd printing messages like: [ 3.030281] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with alignment.service/start [ SKIP ] Ordering cycle found, skipping alignment.service Stop deploying initscripts in our images. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11angstrom-lxde-image: add gpio-tool for apalis-tk1Max Krummenacher
2017-01-11images: update version string to 2.7Max Krummenacher
2017-01-10images: update.sh: Add Apalis TK1 Mainline machineDominik Sliwa
2017-01-10images: remove useless taskMax Krummenacher
When systemd was introduced to OE sysv initscripts did sometimes interfere with systemd services. We deleted them at image creation time. This is no longer done, however a task which creates a no longer called script is still in the recipe. Remove that. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10images: change summary to a common patternStefan Agner
We use the image summary as image name for the Toradex Easy Installer. Since we might end up in a list of images of other operating systems and maybe even other companies, make sure to mention Toradex and Linux. While at it use a common summary pattern across all image recipes. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-10gpio-tool: renamed the tool to gpio-toolMax Krummenacher
Follow the name change in the WinCE team. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10images: use packagegroup-fsl-gpu-libsMax Krummenacher
The old solution with using packagegroup-fsl-tools-gpu with a bbappend to remove the big tools and examples needs more maintanance and makes it hard for someone who really wants the examples or tools in a image. So change to a new packagegroup to deploy the libraries. Also deploy OpenCL releated libraries seperately. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10angstrom-lxde-image: remove udisksMax Krummenacher
Applications now rely on udisk2 which they pull in through dependencies. There is no need to install udisks explicitly. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10GPIOConfig: add variant for colibri-imx7Max Krummenacher
2017-01-10angstrom-lxde-image: remove explicit libwnck deploymentMax Krummenacher
libwnck is anyway now used in its gtk3 flavour. The gtk3 version libwnck3 will get pulled-in through dependencies. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10images: use freeglut instead of mesa-glutMax Krummenacher
mesa-glut was dropped in favour of freeglut in oe. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10images: set version to 2.6.2Max Krummenacher
2017-01-10angstrom-lxde-image: use gtk3 based florenceMax Krummenacher
2017-01-10angstrom-lxde-image.bb: follow package name changes fsl vs. imxMax Krummenacher
2016-09-29apalis-tk1: deploy full mesa-demos in favour of segfaulting eglinfo-x11Marcel Ziswiler
2016-09-29images: set PV to 2.6.1Max Krummenacher
2016-09-28images: mv all files into recipes-image/imageMax Krummenacher
This requires to adjust the path to include files, e.g.: -require recipes/images/trdx-image-fstype.inc +require recipes-images/images/trdx-image-fstype.inc Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
