While at it also reflect changed name of tdx-nv-binaries.
LXDE: LinuxImage -> LXDE-Image
Qt4: LinuxImage-qt -> Qt4-X11-Image
Qt4 embedded: LinuxImage-qte -> Qt4e-Image
Qt5: LinuxImage-qt5 -> Qt5-X11-Image
Console: LinuxConsoleImage -> Console-Image
Additionaly the underscore in the machine name is replaced by a dash
so that the image name is now comprised of 3 elements which themselfes
do not contain an underscore but are separated by underscores.
<machine>_<image type>_version
e.g.:
Apalis_iMX6_LinuxImageV2.7_20170327.tar.bz2
becomes
Apalis-iMX6_LXDE-Image_2.7b2-20170327.tar.bz2
The package initscripts deploys some SysV initscripts which were still
required for earlier systemd version. All services are now available
through systemd, so this is not necessary anymore. It even leads to
interference with systemd printing messages like:
[ 3.030281] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with alignment.service/start
[ SKIP ] Ordering cycle found, skipping alignment.service
Stop deploying initscripts in our images.
When systemd was introduced to OE sysv initscripts did sometimes interfere
with systemd services. We deleted them at image creation time.
This is no longer done, however a task which creates a no longer called
script is still in the recipe. Remove that.
We use the image summary as image name for the Toradex Easy Installer.
Since we might end up in a list of images of other operating systems
and maybe even other companies, make sure to mention Toradex and Linux.
While at it use a common summary pattern across all image recipes.
Follow the name change in the WinCE team.
The old solution with using packagegroup-fsl-tools-gpu with a
bbappend to remove the big tools and examples needs more maintanance
and makes it hard for someone who really wants the examples or tools
in a image.
So change to a new packagegroup to deploy the libraries.
Also deploy OpenCL releated libraries seperately.
Applications now rely on udisk2 which they pull in through
dependencies. There is no need to install udisks explicitly.
libwnck is anyway now used in its gtk3 flavour. The gtk3 version
libwnck3 will get pulled-in through dependencies.
mesa-glut was dropped in favour of freeglut in oe.
This requires to adjust the path to include files, e.g.:
-require recipes/images/trdx-image-fstype.inc
+require recipes-images/images/trdx-image-fstype.inc
