- Drop LICENSE from graphical-tdx-image and verification-tdx-image,
it's already defined in console-tdx-image recipe.
- Drop deprecated variables ROOTFS_PKGMANAGE_PKGS, IMAGE_DEV_MANAGER,
IMAGE_INIT_MANAGER, IMAGE_INITSCRIPTS, IMAGE_LOGIN_MANAGER.
- timestamp-service is a systemd specific package, install it only for
systemd distro.
- Change udev-extra-rules to udev-extraconf, udev-extraconf is the new
name after merging udev-extraconf and udev-extra-rules in OE:
[ 0ca3a7823: udev-extraconf: Merge with udev-extra-rules from meta-oe ]
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Install the wifi firmware group to the image.
Firmware files required by several wifi devices including
mrvl8688/rtl8188 that provide by Toradex as on-module and standalone
USB solutions.
Related-to: ELB-2789
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
The downstream kernel gets to old to be used with the new zeus
userspace components. Reuse the apalis-tk1 machine name to build
a mainline kernel and drop the apalis-tk1-mainline machine.
Related-to: ELB-2733
This is meant to replace the current demo images.
The console and graphical image can be used as a base to create tailored
images to the requirment of a specific use case.
The verification image is meant to test the BSP. It provides the tools
to exercise the CPU / GPU / VPU and the various SOC peripherals.
Related-to: ELB-1284
Include a launcher for the weston-terminal if built for wayland/xwayland.
Rework that the X11 launcher is only used if not using xwayland.
packagegroup-base-extended is installed by inheriting core-image.
packagegroup-basic installs dropbear, openssh-sftp, openssh-sftp-server
dropbear can act as an scp client, drop openssh-scp
Define the string used for each machine in the machine configuration
rather than doing this in each image recipe.
Fallback to machine configuration name if not defined.
If a build is configured for a wayland or xwayland graphical backend
install an sample application too.
Without this xinit fails because /usr/bin/x-window-manager does not exist
and systemd then indefinitely retries to start X11.
This is a follow-up to:
e1026cf43 images: do not explicitely install ${XSERVER}
We decided we won't do a BSP 3.0 for Vybrid.
For new designs we recommend ULL now.
Use the Toradex Easy Installer instead.
If you included tdx-image-fstype.inc in your image recipes you will have
to remove that include.
These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply to high. Keep using the rocko based 2.8 BSP for these machines.
Tezi now shows the image description more prominently. Update the standard
image descriptions using DESCRIPTION.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Some image features (e.g. tools-debug) do not currently work with the
console-tdx-image. The reason is that it is inheriting from the image
class instead of the core-image class, which defines such extra
features. Fortunately, this change doesn't need extra modifications in
the file. The documentation shows core-image inheritance as the standard
way to create new images, so we are advised to do it this way from now
on.
uClibc has been removed in morty.
Images for tk1 and tk1-mainline are currently indistinguishable
especially when path to the image is long. For now simply append the
description with " (Mainline)" should work. Let’s integrate this into
our builds.
With the removal of meta-systemd one no longer needs to add
connman-systemd to the image to get the systemd service files
installed and enabled.
Use PV variable to define the image version. With that the Tezi
image class can use OpenEmbedded variables to get the image version.
