path: root/recipes-images/images/files/colibri-imx6ull/colibri-imx6ull_bin/flash_blk.scr
2017-11-27colibri-imx6ull: add dtb for wifi variantMax Krummenacher
Deploy the device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT and choose the write one to flash into its UBI partition. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-10-03flash_blk/eth.scr: replace loadaddr by fdt_addr_rMarcel Ziswiler
Unfortunately as loadaddr is equal to fdt_addr_r on some modules and equal to kernel_addr_r on others using it together with any of the others may cause issues. Therefore no longer make use of loadaddr and consistently use fdt_addr_r instead. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03images: add colibri-imx6ullMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
