2014-08-04 | apalis-imx: update kernel to 3.10.17 | Max Krummenacher | |
Base kernel on Freescales 3.10.17_1.0.0_ga and provide a device tree plus code changes for Apalis iMX6. | |||
2014-08-04 | colibri-vf: update kernel to latest, port recipe for use with daisy | Max Krummenacher | |
2014-08-04 | linux-toradex-fsl: remove linux-toradex-fsl.inc usage | Max Krummenacher | |
2014-05-20 | colibri-vf: switch back to latest git on colibri_vf branch | Marcel Ziswiler | |
This commit switches Colibri VF machine back to use the colibri_vf branch and use the latest Linux kernel. | |||
2014-04-30 | colibri-vf: switch to U-Boot 2014.04 and latest git | Stefan Agner | |
This commit switches Colibri VF machine to use the 2014.04 git branch. The change to latest U-Boot brings proper NAND hardware ECC support, which is also enabled in latest Linux kernel. Beside that, burnflash is updated to correctly work with the new U-Boot version and the altered Config Block location. | |||
2014-04-05 | linux-toradex-fsl_git: fix parsing | Max Krummenacher | |
Make the bitbake parser not fail when this recipe is parsed for a machine for which this recipe is not a COMPATIBLE_MACHINE. | |||
2014-04-03 | kernel: apalis-imx6 update to latest git version | Max Krummenacher | |
2014-04-02 | kernel: apalis-imx6 update to latest git version | Max Krummenacher | |
2014-04-01 | kernel: add Apalis iMX6 and Colibri VF recipe | Max Krummenacher | |
