2014-10-29 | lxdm: switch to 0.5/git version | Stefan Agner | |
Switch to newer LXDM which supports logind as login/session management. | |||
2014-10-24 | colibri_vf: detect module type on dt kernels | Stefan Agner | |
Detect the module type using the compatible property of the device tree to symlink the module specific background image. | |||
2014-10-06 | lxde-common_0.5.5: add Colibri iMX6 specific wallpapers | Max Krummenacher | |
2014-08-04 | lxde: move base recipes to meta-lxde | Max Krummenacher | |
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-05-28 | lxde-common: remove obsolete commands in autostart | Max Krummenacher | |
- remove workarounds for hdmiaudio and xrandr which are no longer needed. - while at it fix some whitespace issues | |||
2014-04-01 | lxde-common_0.5.5: add iMX6 specific wallpapers | Max Krummenacher | |
2013-11-21 | lxde-common: choose wallpaper for colibri-vf at runtime | Max Krummenacher | |
2013-10-17 | lxpanel: add module dependent browser to launch bar | Max Krummenacher | |
For tegra use firefox, for vybrid midori | |||
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-09-22 | lxdm: path to greeter changed, adapt conf file | Max Krummenacher | |
2013-09-22 | lxlauncher: fix FILES variable | Max Krummenacher | |
2013-09-22 | lxappearance-obconf: update to 0.2.0 | Max Krummenacher | |
2013-03-20 | Wallpaper: correct new CI colors | Max Krummenacher | |
2013-03-04 | lxde-common: wallpapers are MACHINE_ARCH dependent | Max Krummenacher | |
2013-01-29 | wallpaper, change to new Toradex CI | Max Krummenacher | |
2013-01-29 | wallpaper, added Apalis-T30 | Max Krummenacher | |
2013-01-23 | wallpaper: renamed in preparation of upcomming Apalis | Max Krummenacher | |
2012-10-18 | removed *~ backup files from git repo | Max Krummenacher | |
2012-10-18 | lxdm: start it as a systemd service | Max Krummenacher | |
2012-10-18 | lxpanel, obconf, moved general changes to oe-tworaz/meta-lxde | Max Krummenacher | |
2012-10-18 | lxrandr, changes needed by newer autotools | Max Krummenacher | |
2012-10-18 | lxdm, moved general changes to oe-tworaz/meta-lxde | Max Krummenacher | |
2012-10-18 | initscript provided in oe-tworaz/meta-lxde | Max Krummenacher | |
2012-08-23 | Use kernel and u-boot from git.toradex.com | Max Krummenacher | |
Move changes done to other repos into .bbappends in meta-toradex | |||
2012-08-15 | L4T R15, oe-core Image V2.0Beta1 | Max Krummenacher | |
2012-07-17 | append our V1.1 lxde specialities to the oe-tworaz recipes | Max Krummenacher | |
2012-06-03 | Initial commit | Max Krummenacher | |
