path: root/recipes-lxde
2015-05-12recipes: don't use ${PN} as a recipe name placeholderMax Krummenacher
${PN} might be extended with some magic prefix, so don't use it in SRC_URI assignments et. al.
2015-05-12lxde-common: use generic panel-buttons.patchMax Krummenacher
There is no difference between iMX6 / Tegra based modules
2015-05-12lxde-common: remove screenlock from panelMax Krummenacher
2015-05-12lxde-common: move version to % placeholderMax Krummenacher
remove consistent_defconfig_dirs.patch as it is no longer needed starting with 0.5.6 consistent_defconfig_dirs.patch is no longer needed. change bbappend to contain % instead of the version
2015-03-31lxde-icon-theme: move version to % placeholderMax Krummenacher
2014-11-13apalis/colibri_imx6: fix wallpaperMarcel Ziswiler
2014-10-29lxdm: switch to 0.5/git versionStefan Agner
Switch to newer LXDM which supports logind as login/session management.
2014-10-24colibri_vf: detect module type on dt kernelsStefan Agner
Detect the module type using the compatible property of the device tree to symlink the module specific background image.
2014-10-06lxde-common_0.5.5: add Colibri iMX6 specific wallpapersMax Krummenacher
2014-08-04lxde: move base recipes to meta-lxdeMax Krummenacher
2014-08-04bbappends: remove the deprecated PRINC variableMax Krummenacher
2014-05-28lxde-common: remove obsolete commands in autostartMax Krummenacher
- remove workarounds for hdmiaudio and xrandr which are no longer needed. - while at it fix some whitespace issues
2014-04-01lxde-common_0.5.5: add iMX6 specific wallpapersMax Krummenacher
2013-11-21lxde-common: choose wallpaper for colibri-vf at runtimeMax Krummenacher
2013-10-17lxpanel: add module dependent browser to launch barMax Krummenacher
For tegra use firefox, for vybrid midori
2013-10-10colibri-vf50: add the machine, kernel and u-bootMax Krummenacher
- also add the relevant configuration files
2013-09-22lxdm: path to greeter changed, adapt conf fileMax Krummenacher
2013-09-22lxlauncher: fix FILES variableMax Krummenacher
2013-09-22lxappearance-obconf: update to 0.2.0Max Krummenacher
2013-03-20Wallpaper: correct new CI colorsMax Krummenacher
2013-03-04lxde-common: wallpapers are MACHINE_ARCH dependentMax Krummenacher
2013-01-29wallpaper, change to new Toradex CIMax Krummenacher
2013-01-29wallpaper, added Apalis-T30Max Krummenacher
2013-01-23wallpaper: renamed in preparation of upcomming ApalisMax Krummenacher
2012-10-18removed *~ backup files from git repoMax Krummenacher
2012-10-18lxdm: start it as a systemd serviceMax Krummenacher
2012-10-18lxpanel, obconf, moved general changes to oe-tworaz/meta-lxdeMax Krummenacher
2012-10-18lxrandr, changes needed by newer autotoolsMax Krummenacher
2012-10-18lxdm, moved general changes to oe-tworaz/meta-lxdeMax Krummenacher
2012-10-18initscript provided in oe-tworaz/meta-lxdeMax Krummenacher
2012-08-23Use kernel and u-boot from git.toradex.comMax Krummenacher
Move changes done to other repos into .bbappends in meta-toradex
2012-08-15L4T R15, oe-core Image V2.0Beta1Max Krummenacher
2012-07-17append our V1.1 lxde specialities to the oe-tworaz recipesMax Krummenacher
2012-06-03Initial commitMax Krummenacher
