path: root/recipes-mozilla
2017-01-10firefox_%.bbappend: follow install path changeMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-30firefox: disable annoying default browser checkMarcel Ziswiler
2016-03-14firefox_%.bbappend: follow changed config file locationsMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-10-28firefox: moved patches to meta-browserMax Krummenacher
2015-05-12recipes: don't use ${PN} as a recipe name placeholderMax Krummenacher
${PN} might be extended with some magic prefix, so don't use it in SRC_URI assignments et. al.
2014-08-04firefox: use 10.0.12esrMax Krummenacher
2014-08-04firefox: fix SIGILL abort on startMax Krummenacher
This seems to only happen in our setup. (with gcc provided from meta-linaro, 4.8.3) With a meta-fsl-arm setup + meta-browser firefox starts correctly. (with gcc from oe, meta-oe, 4.8.2)
2014-08-04bbappends: remove the deprecated PRINC variableMax Krummenacher
2013-09-22firefox: updated to 10.0.11esrMax Krummenacher
2013-09-22firefox: bbappend updated to use 10.0.11esrMax Krummenacher
2013-02-05firefox: bookmark the Toradex Cload DemosMax Krummenacher
2012-12-17firefox: set develper.toradex.com as the homepageMax Krummenacher
2012-10-18firefox, add alignment patchMax Krummenacher
