Qt 4 was first released in 2005 and has been unsupported since 2015.
Drop it from what we regularly install.
These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply to high. Keep using the rocko based 2.8 BSP for these machines.
qtwebkit bb no longer supports the use of gstreamer 0.10 packageconfig.
Also it looks like qtwebkit itself no longer picks up a 0.10 installation.
qt3d picks up the configured flavours of OpenGL from qtbase.
So add them to DEPENDS or one gets linker errors.
With commit 7193a7f1f meta-qt5 removed qtquick1.
Remove qt plugins already pulled in from RRECOMMENDS.
As qt5.inc sets
RRECOMMENDS_${PN} = "${PN}-plugins ${PN}-qmlplugins"
there is no need to to add plugins for which ${PN} is already included.
As with Qt 5.8 qtdeclarativ-plugins is empty this fixes:
| Collected errors:
| * calculate_dependencies_for: Cannot satisfy the following dependencies for packagegroup-qt5:
| * qtdeclarative-plugins *
| * opkg_solver_install: Cannot install package packagegroup-qt5.
Use '${COMMON_LICENSE_DIR} for license files
fix the warning:
| WARNING: packagegroup-xfce-base-1.0-r5 do_populate_lic:
| ${COREBASE}/LICENSE is not a valid license file, please use
|'${COMMON_LICENSE_DIR}/MIT' for a MIT License file in LIC_FILES_CHKSUM.
|This will become an error in the future
While at it only differ in PACKAGECONFIG if really needed.
Empty RDEPENDS are not needed, the others are automatically added
by the buildsystem.
Qt5.7 no longer provides fonts. Enable the 'fontconfig' PACKAGECONFIG
so that Qt5 finds OE installed fonts.
Patch gets now applyed in meta-qt4.
This reverts commit 990b54bc5cd767a2c687bae77ca1c79e40c79c0d
qtquickcontrols are only built if qtbase gets configured with accessibility.
The base_contains function is deprecated and we ought to use
bb.utils.contains instead.
qtdemo-init exists in another recipe for qte. When both recipes are
built we get an error during sysroot deployment.
- use % in bbappend
- tegra: build with icu, so qtwebkit can be built
- tegra: build with gstreamer 0.10
- remove workaround for gcc 4.8
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
While at it replace Tegra machines with SOC family
recipes-qt/qt4/qt4-x11-free_4.8.5.bbappend
Convert qt-demo-init to a systemd service. The service will only
start when the systemd target is set to graphical, hence also set
the new default target of the qt4e-demo-image to graphical.
Due to the move to systemd, all init scripts located under /etc/init.d
get deleted by the inherited systemd recipes (systemd.inc). Since we
don't use the script as a system V init script, we can move the script
to /usr/bin.
Since we explicitly ask to build Qt for OpenGL ES2, we should also
make OpenGL ES2 as a explicit dependency.
with the move from meta-openembedded to oe-core some things have
changed, e.g. the config files have to explicitly installed
- bbappends to the base qt4-x11-free recipe to use OpenGL ES2
- script which starts X plus qtdemo, including a systemd service to activate script
