2016-09-28 | gpioconfig: mv all files into recipes-support/gpioconfig | Max Krummenacher | |
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> | |||
2016-06-30 | florence: build without sound and drop gstreamer 0.10 dependency | Max Krummenacher | |
add configure options to build without sound. This removes the runtime dependency on gstreamer 0.10. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2016-06-30 | florence: move to latest GTK2 version 0.5.4 | Stefan Agner | |
The latest GTK2 version is 0.5.4, which contains several bug fixes. Noteable, it fixes an issue where the SVG keys have not been displayed with recent versions of its dependencies. Note: This adds GStreamer 0.10 dependency... Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2016-03-14 | icu: upgrade reduced icu data to version 55 | Max Krummenacher | |
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com> | |||
2016-03-14 | florence bbappend: remove patches now applied in florence bb | Max Krummenacher | |
2015-08-07 | opencv: update patches for libav 10.x API | Max Krummenacher | |
2015-08-07 | icu: upgrade reduced icu data to version 54 | Max Krummenacher | |
2015-05-12 | florence: use oe standard download mirror for sourceforge | Max Krummenacher | |
2015-05-12 | opencv: add patches for libav 10.x API | Max Krummenacher | |
2015-05-12 | recipes: replace short DESCRIPTION with SUMMARY | Max Krummenacher | |
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY. | |||
2015-05-12 | i2ctools: don't install the perlscript and perl | Max Krummenacher | |
Mechanism changed to what the bb file now offers. | |||
2015-05-12 | icu: upgrade reduced icu data to version 53 | Max Krummenacher | |
While at it move version to % placeholder and use wildcards in receipe icu: use wildcard to be independent of version | |||
2015-03-31 | gnutls: remove bbappend | Max Krummenacher | |
gnutls recipe now detects pthread in configure task correctly. | |||
2015-03-31 | FILESEXTRAPATHS_prepend: add proper list separator | Max Krummenacher | |
2014-12-18 | mcc-pingpong: alter CFLAGS to use the actual kernel headers | Stefan Agner | |
To use the kernel interfaces required for mcc-pingpong we need the kernel headers of the actual kernel. Alter CFLAGS to add the kernel headers to the include path. | |||
2014-12-11 | consolekit: add systemd to DEPENDS if needed | Max Krummenacher | |
2014-08-04 | gnutls: hack to use libpthread | Max Krummenacher | |
gnutls use libgcrypt and should init gcrypt's mutex functionality but does not. This leads to asserts in libgcrypt: Ohhhh jeeee: Assertion `pool_is_locked' failed (random-csprng.c:615:mix_pool) This patch hacks autoconf to always use libpthread and thus initalizes libgcrypt with working mutex functions. | |||
2014-08-04 | libpcre: Use generic bbappend versioning | Max Krummenacher | |
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-08-04 | Use generic bbappend files | Max Krummenacher | |
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it. | |||
2014-05-02 | mcc-pingpong: demo application for ping pong with Cortex M4 | Stefan Agner | |
2014-04-30 | icu: add break iterator support for webkitgtk | Stefan Agner | |
Webkitgtk needs break iterator support in order to work. This avoids segmentation fault when using Midori web browser. | |||
2014-04-04 | icu: update to match bb version | Max Krummenacher | |
2014-03-31 | icu: is machine specific for colibri-vf | Max Krummenacher | |
For colibri-vf we deploy icu only partly to save diskspace, so set the PACKAGE_ARCH for that machine. | |||
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-10-16 | icu: fix SRC_URI | Max Krummenacher | |
2013-10-11 | icu: replace database with minimzed version | Max Krummenacher | |
2013-10-09 | i2c-tools: don't install the perl scripts (and thus don't RDEPEND on perl) | Max Krummenacher | |
2013-09-22 | florence: RDEPEND on svg support to draw icon | Max Krummenacher | |
2013-09-22 | libfm: bbappend updated to 1.1 | Max Krummenacher | |
2013-09-22 | libpcre: bbappend update to 8.32 | Max Krummenacher | |
2013-04-02 | florence: fix garbled titlebar | Max Krummenacher | |
2013-02-06 | libfm: set lxterminal as the terminal application | Max Krummenacher | |
2012-10-18 | libvpx, version update in oe-core | Max Krummenacher | |
2012-08-27 | nautilus depends on gobject-introspection-native | Max Krummenacher | |
libpcre splits into libpcre-*, use packages-dynamic so we can put them into an image rename bbappend because coresponding bb does not exist |
