Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
Unifing with imx6 update script pulled in a test that a device-tree
must be deployed. Apalis/Colibri T30 use a not device-tree enabled
Kernel. So remove the check that the device-tree actually exists.
Make the option -o mandatary, used to default to /media/KERNEL
While at it synchronize the files again.
Update to latest version (SVN r671) of burnflash.
Pull out common files of the module specific trees into the common library
directory and symlink the files.
