Use latest U-Boot from git.
Migrate to using cbootimage and tegrarcm.
Remove explicit installation of ConsoleKit since we use systemd-
logind nowadays. Also, pam-plugin-ck-connector, the ConsoleKit pam
plug-in, is not required anymore. The equavilent for systemd is
part of libpam (pam_systemd.so).
The secondary PolKit authenticatin agent polkit-gnome is not
necessary since LXDE has its own authentication agent lxpolkit.
Due to U-Boot udpate we need to create one big UBI volume. Since
attaching the UBI volume is the expensive operation (compared to
mount the UBIFS inside that volume), it is relatively cheep to
load the kernel directly from the root filesystems /boot directory
instead of creating a own volume for the kernel. This also makes
it simpler to load a mainline kernel (along with the required dtb
file).
However, we loose the integrity check of the uImage. But since
there were no measures in place to handle a invalid image, we do
not loose functionality here. In case we need integrity check, we
should consider switching to the new FIT image format...
BAD_RECOMMENDATIONS seems to not work if more than one package is given
and all packages get installed.
So only give one.
On top of that, if a package is available from multiple feeds the
package gets installed.
Don't install gnome-disk-utility on Vybrid based modules to save space.
u-boot-fw-utils allows for U-Boot environmenmt access from Linux
gpio-export exports the unused GPIOs
usb-rndis sets up RNDIS and a DHCP server on the usb0 NIC
Use the available set of GSTREAMER packages and append the i.MX6 specific ones
to the list instead of providing a new list
Append instead of overwritting the DEPENDS variable.
gnome-disk-utility is no longer implicitely included.
Set image version to V2.3
do_rootfs is now written in python, so no appends with shell scripts.
Replace appends with new tasks.
Set the default systemd target on images that launch X as this is no
longer the default.
Remove the unneeded LIC_FILES_CHKSUM
Patch pending in meta-angstrom
Don't fail for images which do not deploy /boot/uImage
mx6: only strip binaries
With the change to our own u-boot recipes the bbappend to
the common u-boot-fw-utils recipe is no longer a sane solution.
While at it cleanup COMPATIBLE_MACHINE style.
- build and deploy imx_usb, imx_uart
- currently it builds for the build host arch, i.e x86-64 or i386
tinylogin has been deprecated and the functionality ported into busybox,
so we switch to using busybox as the default login manager.
http://cgit.openembedded.org/openembedded-core/commit/?id=54fc2a698d49f7acc93c8e4b6f6c4e7b3b6ffcc8
Apalis T30 and Colibri VFxx modules have IEEE 1588 (Precision Time Protocol)
capable Ethernet NIC's.
This adds the userspace daemon to such hardware.
The MCC (Multi-Core Communication) is the subsystem that enables MQX
applications running on the M4 core to communicate with Linux
applications on the A5 core
- move pam-plugin-ck-connector to LXDE image
- remove connman-gnome from Qt image
Add kernel module for Fusion 7"/10" touch screen to the root
filesystem image.
Add the fstrim utility to Colibri T30 image. The utility allows to
send trim commands to the underlaying flash translation layer, which
allows too free not used flash sectors and those improve wear-
leveling
still missing automatic start of a demo
(and detecting keyboard, mouse, touch)
export QWS_DISPLAY="LinuxFb:/dev/fb:depth=24"
export QWS_KEYBOARD="USB:/dev/input/event1"
export QWS_MOUSE_PROTO="LinuxInput:/dev/input/event2"
qtdemoE -qws
