Remove debug feed URL as it does not exist.
Re-add Colibri T20 specific (ARM, hard-float, non-neon) feeds which
recently are built in Angstrom again as Atmel SAMA5D3 is non-neon as
well.
- Colibri T30 and Apalis T30 changed to NEON
- Colibri VF50 changed to hard float
This makes packages built for T30 incompatible with Colibri T20
(but Colibri T20 packages can still be used on T30)
- remove links to incompatible architecture feeds
- for Colibri T30, Apalis T30 and Colibri VF50 there are compatible feeds
- for Colibri T20 there are no compatible feeds
