path: root/recipes
2013-10-21feed-config: use the new feed armv7ahf-vfp-neon for T30/VF50Max Krummenacher
2013-10-21hdmi: add udev rule to start an X output on hotplugMax Krummenacher
2013-10-17inputrc: use <HOME> <END> to go to begin/end of lineMax Krummenacher
2013-10-16machines: T30 and VF50 consitstently use NEON and hard floatMax Krummenacher
- Colibri T30 and Apalis T30 changed to NEON - Colibri VF50 changed to hard float This makes packages built for T30 incompatible with Colibri T20 (but Colibri T20 packages can still be used on T30)
2013-10-11images: add a qt4 embedded imageMax Krummenacher
still missing automatic start of a demo (and detecting keyboard, mouse, touch) export QWS_DISPLAY="LinuxFb:/dev/fb:depth=24" export QWS_KEYBOARD="USB:/dev/input/event1" export QWS_MOUSE_PROTO="LinuxInput:/dev/input/event2" qtdemoE -qws
2013-10-11feed-config: remove non working feeds, add feeds for T30 VF50Max Krummenacher
- remove links to incompatible architecture feeds - for Colibri T30, Apalis T30 and Colibri VF50 there are compatible feeds - for Colibri T20 there are no compatible feeds
2013-10-11console-image: fix the inclusion of X11Max Krummenacher
2013-10-10colibri-vf50: add the machine, kernel and u-bootMax Krummenacher
- also add the relevant configuration files
2013-10-10image-fstype: add colibri-vfxx moduleMax Krummenacher
2013-10-10images: cleanup, add colibri-vfxx moduleMax Krummenacher
- Add optimizations needed for the Colibri VFxx modules - Move common stuff to trdx-extra.inc, /etc/timestamp, CAN utils - Cleanup whitespace and commented stuff - Split out gstreamer packages, don't add them on Colibri VFxx angstrom-lxde-image: - Browser for Colibri VFxx is midori for size reasons console-image: - don't add X11 for Colibri VFxx
2013-09-22images: use consistent image namesMax Krummenacher
- use consistent image names - while at it build the GLES samples only for a tegra machine
2013-09-22image: add handling for imx u-boot extensionMax Krummenacher
2013-09-22image: add update-alternative and ethtoolMax Krummenacher
2013-09-22connman: add commandline configuration toolMax Krummenacher
root@colibri-t30:~# connmanctl connmanctl> services *AO Wired { ethernet_00142d259a48_cable } connmanctl> services ethernet_00142d259a48_cable [ ethernet_00142d259a48_cable ] Type = ethernet Security = [ ] State = online Favorite = True Immutable = False AutoConnect = True Name = Wired Ethernet = { Method=auto Interface=eth0 Address=00:14:2D:25:9A:48 MTU=1500 } IPv4 = { Method=dhcp Address=192.168.10.2 Netmask=255.255.255.0 Gateway=192.168.10.1 } IPv4.Configuration = { Method=dhcp } IPv6 = { } IPv6.Configuration = { Method=auto Privacy=disabled } Nameservers = [ 192.168.0.32 ] Nameservers.Configuration = [ ] Timeservers = [ 192.168.0.32 ] Timeservers.Configuration = [ ] Domains = [ ] Domains.Configuration = [ ] Proxy = { Method=direct } Proxy.Configuration = { } Provider = { } connmanctl> config ethernet_00142d259a48_cable --ipv4 manual 192.168.10.2 255.255.255.0 192.168.10.1 connmanctl> exit root@colibri-t30:~# connmanctl connmanctl> config ethernet_00142d259a48_cable --ipv4 dhcp connmanctl> exit
2013-09-22inhibit missing debug info warnings in binary packageMax Krummenacher
2013-09-22stress: correct license textMax Krummenacher
remove backup file while at it
2013-09-22lxde: use renamed recipe packagegroup* recipeMax Krummenacher
2013-09-22remove obsolete filesMax Krummenacher
2013-09-22libxi: provide dummy recipe - libxi.bbappend in a layer breaks buildMax Krummenacher
2013-09-22update-modules: this package is replaced by other postinstMax Krummenacher
2013-09-22console-image: use require instead of includeMax Krummenacher
2013-09-22image: remove line concatenations '\' from commentsMax Krummenacher
2013-09-22gpioconfig: fix RDEPENDS to include ${PN}Max Krummenacher
2013-08-19apalis image: add the v4l camera driver kernel modulesMax Krummenacher
2013-08-19image: add v4l-utilsMax Krummenacher
2013-07-26trdx-config: remove obsolete packageMax Krummenacher
2013-06-26image: move the pixbuf loader update to rootfs creationMax Krummenacher
2013-06-26fs-init: add recipe to extend rootfs partition on eMMCMax Krummenacher
- on Colbri/Apalis T30 the rootfs is downloaded in a minimum size. On first boot this filesystem is resized to fill its full partion. This slows down IO responsivness during the first 5 minutes.
2013-06-26burnflash: unified T20/T30Max Krummenacher
- unified the burnflash sources to work on Colibri T20/T30, Apalis T30 - change the PXA dummy burnflash accordingly - increase the initial free rootfs space to 100M on eMMC partition will be resized on first boot to full partition size relevant for Colibri T30, Apalis T30
2013-06-26image: add gstreamer deinterlacer used with cameraMax Krummenacher
2013-06-17stress: download site is down, added mirrorMax Krummenacher
2013-06-07lxde-image: add scrot, add underscore to apalis tar filenameMax Krummenacher
2013-04-15trdx-extra: cleanup indentionMax Krummenacher
2013-03-27images: added a QT4 X11 imageMax Krummenacher
- bbappends to the base qt4-x11-free recipe to use OpenGL ES2 - script which starts X plus qtdemo, including a systemd service to activate script
2013-03-20florence: add virtual keyboard to imageMax Krummenacher
2013-03-07image: add setxkbmap packageMax Krummenacher
2013-03-04remove unused filesMax Krummenacher
2013-03-04image: remove intermediate file before creating tarballMax Krummenacher
2013-03-04added filesystem tools, Apalis: added lvds configuration scriptsMax Krummenacher
2013-02-15max9526: added a gtk version for Colibries onlyMax Krummenacher
2013-02-05GPIOConfig: Colibri-t30 GPIO to SODIMM assignmentMax Krummenacher
- Colibri T30 V1.1 has a different assignment of GPIO to SODIMM pins
2013-02-05image: image name now defined in the image.bb filesMax Krummenacher
2013-01-29max9526: install on all modulesMax Krummenacher
2013-01-29image: add Apalis-T30 specific packagesMax Krummenacher
2013-01-29base-files: add Apalis-T30Max Krummenacher
2013-01-29max9526: i2c userspace driverMax Krummenacher
- sets some registers to setup chip on our ACM analog camera module board
2013-01-29glmark2: add recipe for linaro glmark2Max Krummenacher
2013-01-29burnflash: add Apalis-T30 as a deployable imageMax Krummenacher
2013-01-22GPIOConfig: fix issues with T30Max Krummenacher
- fix GPIO numbers > 222 not working correctly - fix handling of tristate - fix strings for first alternate function
2012-12-07images: add gstreamer plugin mp3, WiFi Firmware, usb-rndisMax Krummenacher
- provide gstreamer plugins which now are required for nvidias mp3 decoder - add firmware for Ambicom WL250N-USB WiFi, - add configuration for usb-rndis
