path: root/release-notes
2016-09-29colibri_imx7: updated release notesMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29apalis/colibri_imx6/t30: updated release notesMarcel Ziswiler
The V2.6 Embedded Linux BSPs for iMX6 and T30 modules are the first stable software releases for those modules. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-08-17updated release notesMarcel Ziswiler
2016-06-30i.MX 7: mention FreeRTOS issue in release notesStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24i.MX 6: add gstreamer issue to release noteMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24Updated release notes.Marcel Ziswiler
2016-03-30Colibri_iMX7: add initial release notesMax Krummenacher
2016-03-14Apalis_iMX6_LinuxReleaseNotesV2.x.txt: document update_it bugMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-12-17Updated release notes.Marcel Ziswiler
2015-12-15Colibri iMX6: updated release notesMax Krummenacher
2015-11-09Apalis/Colibri iMX6: updated release notesMax Krummenacher
2015-11-06Updated release notes.Marcel Ziswiler
2015-08-17colibri-vf: updated release notesMarcel Ziswiler
2015-08-14colibri-vf: updated release notesMarcel Ziswiler
2015-07-09updated release notesStefan Agner
Add USB mass storage mishap.
2015-05-29Clean-up Colibri T20 release notes after recent pull/rename.Marcel Ziswiler
2015-05-29Actually rename Colibri T20 release notes meant for BSP V2.3.Marcel Ziswiler
2015-05-29Pulled in Colibri T20 release notes from V2.3-next branch applicableMarcel Ziswiler
for V2.3 stable image.
2015-05-29Rename Colibri T20 release notes now valid from BSP V2.4 onwards.Marcel Ziswiler
2015-05-22updated release notesMarcel Ziswiler
2015-05-19updated release notesMarcel Ziswiler
2015-03-25Update release notesMarcel Ziswiler
2015-02-12Update release notesMarcel Ziswiler
2015-02-06Apalis/Colibri iMX6: Update release notesMax Krummenacher
Add issue with getty also started on ttymxc1.
2015-02-04Colibri VF50/VF61: Update release notesStefan Agner
2015-01-13Apalis iMX6: Update release notes for Beta6Max Krummenacher
2015-01-09Apalis iMX6: Update release notesMax Krummenacher
2014-12-19Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notesMarcel Ziswiler
2014-12-08Colibri iMX6: Update release notesMax Krummenacher
Add update of single component U-Boot/Kernel/FDT Remove unavailable interfaces from the list of notworking Add correct git tag
2014-12-08Release Notes: fix changed URLMax Krummenacher
While at it remove supperseeded release note
2014-12-08Colibri iMX6/T30: Add/Update release notesMax Krummenacher
Add inital release notes for Colibri iMX6 Fix Colibri T30, EvalBoard MMC connector designator
2014-12-08Apalis/Colibri T30: Update release notesMax Krummenacher
Workaround for resize script
2014-11-13Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notesMarcel Ziswiler
2014-11-05Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notesMarcel Ziswiler
2014-11-03Apalis/Colibri T30: Fixed release notesMarcel Ziswiler
Got the U-Boot stuff mixed up.
2014-11-03Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notesMarcel Ziswiler
2014-10-06apalis-imx6: Release notes: update from V2.2 on IxoraMax Krummenacher
Conflicts: release-notes/Apalis_iMX6_LinuxReleaseNotesV2.x.txt
2014-09-14apalis/colibri iMX6/T20/T30/VF50/VF61: Update release notesMarcel Ziswiler
2014-09-04Apalis T30: Update release notesMarcel Ziswiler
2014-09-02apalis-imx6: Release notes: add notes for PCIe configMax Krummenacher
2014-09-02apalis-imx6: Release notes: add saveenv to env updateMax Krummenacher
2014-09-02apalis-imx6: Release notes: Use webfriendly " charMax Krummenacher
2014-08-05apalis/colibri iMX6/T20/T30/VF50/VF61: Update release notesMarcel Ziswiler
2014-06-12release notes: extend Colibri VF UART recovery notesStefan Agner
Add hint for non-fused modules, document recovery mode on Iris.
2014-06-10release notes: update Colibri VF release notesStefan Agner
Update Colibri VFxx release notes to reflect latest release V2.2 Beta 1.
2014-04-08Added note about Apalis iMX6 SSH password authentication beingMarcel Ziswiler
disabled by default. While at it line wrapped Apalis T30 release notes document.
2014-04-04Apalis_iMX6: add initial rlease notesMax Krummenacher
2014-03-20release notes: Colibri VF: add boot hang issueStefan Agner
Add boot hang issue to known bugs.
2014-03-18release notes: apalis/colibri t20/t30 colibri vf v2.1 beta 3Max Krummenacher
2014-03-06release notes: vybrid beta 2 release notesStefan Agner
