Add recipe to build mainline kernel. Currently, the 3.17 next branch will
be built. To use this kernel, add this lines to your local.conf
PREFERRED_PROVIDER_virtual/kernel ?= "linux-toradex"
IMAGE_INSTALL_append = "kernel-devicetree"
KERNEL_DEVICETREE += "vf500-colibri-eval-v3.dtb vf610-colibri-eval-v3.dtb"
Also, the multi-core communication packages (mqxboot, libmcc, mcc-pingpong
and kernel-module-mcc) need to be removed from recipes/images/trdx-extra.inc
since the required kernel interfaces are not available on the 3.17 mainline
port.
Angstrom started using thumb2 on machines with armv7-a architectures.
This commit removes our override to stay on arm instruction set, so
if building our machines with the angstrom distribution you now get
thumb2 builds.
Use rebased U-Boot release 2014.10. The README has a new md5sum
and U-Boots new build system has default configurations ending
with defconfig too.
Due to U-Boot udpate we need to create one big UBI volume. Since
attaching the UBI volume is the expensive operation (compared to
mount the UBIFS inside that volume), it is relatively cheep to
load the kernel directly from the root filesystems /boot directory
instead of creating a own volume for the kernel. This also makes
it simpler to load a mainline kernel (along with the required dtb
file).
However, we loose the integrity check of the uImage. But since
there were no measures in place to handle a invalid image, we do
not loose functionality here. In case we need integrity check, we
should consider switching to the new FIT image format...
meta-angstrom backported systemd 2.16 into daisy. Keep using 2.11 for now.
u-boot.inc no longer builds the standalone examples by default so
do patch to not do so is no longer needed.
The source tree will no longer be marked as git dirty.
The enlightement svn seems to be down.
Workaround by using their git repo which provides the same data
and is already used in the master branch of meta-openembedded.
Remove once we upgrade from daisy to the next stable release.
Base kernel on Freescales 3.10.17_1.0.0_ga and provide a device tree plus
code changes for Apalis iMX6.
u-boot-fw-utils allows for U-Boot environmenmt access from Linux.
Add the needed configuration file for colibri_t20 with a postinst script
which choses the right NAND flash sector sizes from /proc/mtd
While at it, fix some whitespace issues.
Angstrom default on armv7a would be thumb2, however there are some
recipes around with arm assembler which fails.
If the package manager finds a version newer than the prefered-version that one
gets installed. As we need a specific one for the tegras and for imx6 we
change the 'epoch' to something very high.
unify the features between machines
kernel26 is deprecated and unused
apm does not make sense on ARM
While at it remove some commented stuff
deleted: recipes-bsp/libmcc/libmcc_1.04.bb
deleted: recipes-bsp/mqxboot/mqxboot_1.0.bb
deleted: recipes-kernel/kernel-module-mcc/kernel-module-mcc_1.04.bb
Patch pending in meta-angstrom
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
Be consistent with the other machine recipes
Help the autobuilder setup
Use the latest U-Boot and burnflash.
This commit switches Colibri VF machine back to use the colibri_vf
branch and use the latest Linux kernel.
The include files (such as linux.inc) are not resolved by priority
but on layer order instead. This can lead to build errors in case
the layers in BBLAYERS are ordered differently.
This commit switches Colibri VF machine to use the 2014.04 git
branch. The change to latest U-Boot brings proper NAND hardware
ECC support, which is also enabled in latest Linux kernel.
Beside that, burnflash is updated to correctly work with the
new U-Boot version and the altered Config Block location.
With the change to our own u-boot recipes the bbappend to
the common u-boot-fw-utils recipe is no longer a sane solution.
While at it cleanup COMPATIBLE_MACHINE style.
Make the bitbake parser not fail when this recipe is parsed for a machine
for which this recipe is not a COMPATIBLE_MACHINE.
File now provided by openembedded-core
This reverts commit 592b1395c7cdff2125b5e42a7f9605749e625419.
adds gpu-viv-bin-mx6q-libraries package which RDEPENDS only the
libraries but not the samples.
