Prepare for configurable boot ROM and SPL payload offsets to be applied
to resp. image.json for Toradex Easy Installer.
Building device tree with a dot in the file name leads to following
ERROR: console-tdx-image-2.7b3-r0 do_image_sdcard: imx6q-apalis-ixora-v1.1.dtb does not exist.
ERROR: console-tdx-image-2.7b3-r0 do_image_sdcard: Function failed: do_image_sdcard
Temporarily remove until we have support for dots in device tree files:
https://github.com/Freescale/meta-freescale/commit/ce1e0af209c222cb877962104c4f807d5807fa1e
Ixora V1.1
Add Ixora V1.1 device tree to Apalis iMX6 OE machine configuration.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
As somebody previously decided to rename U_BOOT_BINARY to UBOOT_BINARY
unbreak e.g. i.MX 6 Tezi builds by continuing that rename through the
various layers:
http://git.toradex.com/cgit/meta-toradex-bsp-common.git/commit/?h=morty&id=02f7fdfe5eaca64e0c710cce4d701a609d499e8b
In our images this has been done during do_rootfs and friends,
do it the oe-core way.
The "tezi" image type has been renamed to "teziimg".
Image formats which include the U-Boot binary rely on U_BOOT_BINARY
pointing to a U-Boot binary working with SPL. U_BOOT_BINARY seems
to point to the last U-Boot binary built, hence move the "spl"
configuration to the end to make sure U_BOOT_BINARY points to the
U-Boot binary which works with SPL.
Enable Toradex Easy Installer image for Apalis iMX6 machine. This
requires to specify the Product Id this machine supports so that
the Installer can filter the images and only show images compatible
with the module currently running on.
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
Use systemd V2.18 from meta-angstrom.
Issues with firmware loading and the 3.1.10 kernel for the tegra machines
are fixed with a backport from oe-core.
Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
The default changed to zImage so explicit set uImage for now.
While at it cleanup the recipe, remove pci from Colibri machine features.
This patch fixes the issue of getting serial tty login at ttymxc1 (UART_B).
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Update to a U-Boot and Kernel which can be used for Apalis iMX6
HW version V1.0 and V1.1.
Also deploy additional device tree for Apalis iMX6 V1.0 modules
Angstrom started using thumb2 on machines with armv7-a architectures.
This commit removes our override to stay on arm instruction set, so
if building our machines with the angstrom distribution you now get
thumb2 builds.
meta-angstrom backported systemd 2.16 into daisy. Keep using 2.11 for now.
If the package manager finds a version newer than the prefered-version that one
gets installed. As we need a specific one for the tegras and for imx6 we
change the 'epoch' to something very high.
unify the features between machines
kernel26 is deprecated and unused
apm does not make sense on ARM
While at it remove some commented stuff
Be consistent with the other machine recipes
Help the autobuilder setup
