2014-04-01 | colibri-vf: use meta-fsl* layer for BSP files | Max Krummenacher | |
remove the files copied from meta-fsl* for Colibri-VF V2.1 move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra | |||
2013-10-14 | vybrid: backport from meta-fsl-arm master-next | Max Krummenacher | |
remove when moving to dora branch |
