Add fw_env.config and make sure unlock eMMC gets installed.
With the new U-Boot MTD partitioning schema mtd3 is used for the
environment.
Without this the default fw_env.config gets deployed.
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream.
fix errors due to missing uint* types.
Move to u-boot git.
Do not use the function keyword, then the script works fine with
with Busybox' shell implementation.
While we use only one erase block for the U-Boot environment, we
reserve four in case there are bad blocks in the environment area.
Specify the number of blocks so that the Linux utilities are able
to read/write the environment even if the first block of the
environment is bad.
Rely on newly implemented configuration functionality to locate the
environment at the end of the boot partition.
Introduce/update postinst code to dynamically adjust fw_env.config and
fw_unlock_mmc.sh shell profile extension script to cope with our new
unified eMMC layout:
boot area partition 1 aka primary eMMC boot sector:
with U-Boot boot loader and the U-Boot environment before the
configblock at the end of that boot area partition
The mmc unlock function causes troubles when using Poky reference
distribution since Poky uses the busybox shell:
/etc/rc5.d/S09xserver-nodm: /etc/profile.d/fw_unlock_mmc.sh: line 2: syntax error: unexpected "("
This avoids X getting at all.
This patch does not solve the underlying problem, but works around it
by moving the script to the u-boot-toradex-fw-utils recipe, which is
not installed by the Poky images by default.
u-boot.inc no longer builds the standalone examples by default so
do patch to not do so is no longer needed.
The source tree will no longer be marked as git dirty.
u-boot-fw-utils allows for U-Boot environmenmt access from Linux.
Add the needed configuration file for colibri_t20 with a postinst script
which choses the right NAND flash sector sizes from /proc/mtd
While at it, fix some whitespace issues.
- they do fail because they don't heed the private libgcc
fix u-boot to no longer fail at runtime, (write beyond array)
