path: root/recipes-bsp/u-boot/u-boot-toradex_2016.11.bb
2017-11-30u-boot-toradex: add dependency on dtc-nativeColibri-iMX6ULL_LXDE-Image_2.7b5-20171201Drew Moseley
Signed-off-by: Drew Moseley <drew.moseley@northern.tech> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-11-28u-boot: update to latest git hashMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-11-27u-boot recipes: automatically update to latest -next through overrideMax Krummenacher
This can be used e.g. for a CI setup to do nightly builds of latest and greatest. To use HEAD of xxx-next instead of the pinned version one would add in local.conf: MACHINEOVERRIDES =. "use-head-next:" Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-10-03u-boot-toradex: fix recipe to work with PokyStefan Agner
Building the recipe with Poky leads to two errors: | error: line 4: invalid tag value("^[A-Za-z0-9+._]+$") Release: Release: 2.7.3-gitr1c83a29 | error: Package has no %description: u-boot-toradex-2016.11.colibri_imx6 Use the + sign to separate the git revision and provide a recipe description. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03u-boot-toradex: fix mixed spl/standard workaroundMax Krummenacher
The workaround for U-Boot being compiled with and without SPL assumes a certain directory structure. For machines only building one U-Boot, the workaround may introduce and error. Fix this. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-10-03u-boot: update to latest git hashStefan Agner
2017-06-30u-boot: update to latestMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-04-10u-boot: use the new version variables for localversionColibri-iMX7_LXDE-Image_2.7b2-20170410Colibri-iMX6_LXDE-Image_2.7b2-20170410Colibri-VF_LXDE-Image_2.7b2-20170410Apalis-iMX6_LXDE-Image_2.7b2-20170410Max Krummenacher
This results in a U-Boot banner: U-Boot 2016.11-2.7.2+g3e67ed8 (Apr 05 2017 - 16:16:38 +0200) While at it extract the versioning into its own bbappend so that we can upstream the base recipe to meta-freescale-3rdparty Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-10u-boot: update to latestMax Krummenacher
2017-04-07u-boot: use the new version variablesMax Krummenacher
2017-04-07u-boot: update to latest -nextMax Krummenacher
2017-01-12u-boot: update to latestColibri_iMX7_LinuxImageV2.7Beta1_20170112Colibri_iMX6_LinuxImageV2.7Beta1_20170112Colibri_VF_LinuxImageV2.7Beta1_20170112Apalis_iMX6_LinuxImageV2.7Beta1_20170112Max Krummenacher
2017-01-10u-boot: update to latest nextMax Krummenacher
2017-01-09u-boot/kernel: update version string to 2.7Max Krummenacher
2017-01-09u-boot: upgrade to 2016.11 based versionMax Krummenacher
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
