2020-04-16 | xorg-xserver: remove duplicated patch | Oleksandr Suvorov | |
The patch 0003-Remove-check-for-useSIGIO-option.patch has been added to xorg-server recipe on meta-freescale layer [1]. Reapplying this patch causes the build error [2]. Remove this patch from the meta-toradex-nxp layer. [1] 07d4a6baa23ec3a1f013f8a070130598b56aec7c xserver-xorg: Backport to fix X server 1.20.1 crash [YOCIMX-3280] [2] ------------------------ ERROR: xserver-xorg-2_1.20.1-r0 do_patch: Command Error: 'quilt --quiltrc /oe-core/build/tmp/work/armv7at2hf-neon-mx6qdl-tdx-linux-gnueabi/ xserver-xorg/2_1.20.1-r0/recipe-sysroot-native/etc/quiltrc push' exited with 0 Output: Patch 0003-Remove-check-for-useSIGIO-option.patch is already applied; check your series file ------------------------ Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> | |||
2019-06-11 | xserver-xorg: fix crash with latest 1.20.1 | Pierluigi Passaro | |
This NXP patch was actually already available in poky layer, but has been removed with commit 9d2cbf041403f5012b251de6c2dc0683755398ed. However, it seems to be mandatory to allow Vivante driver working correctly. Taken from: https://github.com/varigit/meta-variscite-fslc/commit/d51c571a44feca398cebb218cfe9c187976cb5be Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> |
