path: root/recipes-kernel/linux/linux-toradex-mainline-4.14/0022-mfd-as3722-disable-auto-power-on-when-AC-OK.patch
2018-07-27apalis-t30/tk1-mainline: update patchsetMarcel Ziswiler
Latest additions: - 0024-apalis_t30-enable-broken-hpi-on-emmc.patch Avoid a rare soft lockup upon installing an image from within Tezi. - 0025-tegra_defconfig-disable-sound-in-tezi-configuration.patch Avoid keyboard/mouse being unresponsive for 10-15 Seconds. - 0026-apalis_t30-fix-mmc1-cmd-pull-up.patch Avoid issues with higher speed SD cards. - 0027-apalis_t30-pull-up-sd-card-detect-pins.patch Avoid floating SD card detect pins. - 0028-Revert-mmc-tegra-Disable-UHS-I-modes-for-Tegra124.patch Allow for UHS-I modes on TK1. - 0029-mmc-tegra-fix-eMMC-DDR-mode.patch Fix eMMC DDR mode. - 0030-apalis-tk1-enable-ddr52-mode-on-emmc.patch Enable eMMC DDR mode. - 0031-apalis-tk1-force-fixed-ids-for-sdmmc-controllers.patch Avoid re-ordering of SDMMC controller instances. - 0032-apalis-tk1-fix-pcie-reset-for-reliable-gigabit-ether.patch Fix PCIe gigabit bring-up issue on Apalis TK1. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
