2018-02-01 | u-boot, u-boot-fw-utils: update to latestV2.6-nextV2.6 | Marcel Ziswiler | |
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-06-30 | u-boot: integrate apalis-tk1 | Marcel Ziswiler | |
2016-06-30 | u-boot, u-boot-fw-utils: update to latest | Stefan Agner | |
The upgrade is required to match to the latest update scripts which deploy the kernel and device tree into static UBI volumes. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-03-31 | u-boot: update to latest from 2015.04-toradex-next | Marcel Ziswiler | |
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2016-03-30 | u-boot tegra: update to latest -next | Max Krummenacher | |
2015-12-15 | Update all U-Boot versions to latest | Max Krummenacher | |
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2015-11-03 | Update Linux kernel and U-Boot to latest. | Marcel Ziswiler | |
2015-10-30 | apalis/colibri_t20/t30: u-boot/fw-utils: introduce srcbranch notation | Marcel Ziswiler | |
Introduce SRCBRANCH notation for easier switching to our -next branch. | |||
2015-08-07 | u-boot-toradex_git: add virtual/bootloader to PROVIDES | Max Krummenacher | |
2015-08-07 | u-boot: remove obsolete overrides | Max Krummenacher | |
2015-05-18 | Apalis/Colibri: update U-Boot to latest | Max Krummenacher | |
And use 2015.04-toradex branch | |||
2015-05-18 | Apalis/Colibri: update U-Boot to latest in -next | Max Krummenacher | |
2015-05-12 | update to latest u-boot | Max Krummenacher | |
2015-05-12 | update U-Boot and Colibri VFxx Linux to latest git revision | Stefan Agner | |
2015-05-12 | update to latest u-boot | Marcel Ziswiler | |
2015-05-12 | u-boot: use latest from git | Max Krummenacher | |
While at it remove warning about stripped fw_printenv binary when building u-boot-toradex-fsl-fw-utils. | |||
2015-05-12 | apalis/colibri_t20/t30: integrate latest stuff | Marcel Ziswiler | |
2014-12-19 | u-boot/u-boot-fw-utils: update all to latest | Max Krummenacher | |
2014-12-18 | Update all to latest and greatest U-Boot and Linux kernel. | Marcel Ziswiler | |
2014-10-31 | apalis/colibri_t30: introduce fw_printenv/setenv | Marcel Ziswiler | |
2014-10-30 | apalis/colibri_t30: latest u-boot git migrated to cbootimage/tegrarcm | Marcel Ziswiler | |
Use latest U-Boot from git. Migrate to using cbootimage and tegrarcm. | |||
2014-10-06 | u-boot: remove don't build the examples patch | Max Krummenacher | |
u-boot.inc no longer builds the standalone examples by default so do patch to not do so is no longer needed. The source tree will no longer be marked as git dirty. | |||
2014-08-04 | u-boot: update to latest git version | Max Krummenacher | |
2014-08-04 | u-boot-toradex: update to latest git version | Max Krummenacher | |
2014-04-05 | u-boot-fw-utils: provide matching recipes | Max Krummenacher | |
With the change to our own u-boot recipes the bbappend to the common u-boot-fw-utils recipe is no longer a sane solution. While at it cleanup COMPATIBLE_MACHINE style. | |||
2014-04-01 | u-boot: convert bbappend to a bb | Max Krummenacher | |
