path: root/recipes-bsp
2018-02-01u-boot, u-boot-fw-utils: update to latestV2.6-nextV2.6Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-08-17u-boot-toradex-fw-utils: fix bashismmeta-toradex_splitStefan Agner
Do not use the function keyword, then the script works fine with with Busybox' shell implementation. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-08-17u-boot-fw-utils: correct blocks reserved for environmentStefan Agner
While we use only one erase block for the U-Boot environment, we reserve four in case there are bad blocks in the environment area. Specify the number of blocks so that the Linux utilities are able to read/write the environment even if the first block of the environment is bad. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-08-17u-boot-fw-utils: use negative offset for environmentStefan Agner
Rely on newly implemented configuration functionality to locate the environment at the end of the boot partition. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30tegrarcm: build with static libstdc++Colibri_iMX7_LinuxImageV2.6Beta2_20160701Colibri_iMX6_LinuxImageV2.6Beta2_20160701Colibri_VF_LinuxImageV2.6Beta2_20160701Colibri_T30_LinuxImageV2.6Beta2_20160701Colibri_T20_LinuxImageV2.6Beta2_20160701Apalis_iMX6_LinuxImageV2.6Beta2_20160701Apalis_TK1_LinuxImageV2.6Beta2_20160701Apalis_T30_LinuxImageV2.6Beta2_20160701Marcel Ziswiler
2016-06-30apalis-tk1: lvds-tegra124: disable lvds by defaultMarcel Ziswiler
Disable LVDS output in favour of primary HDMI one on Apalis TK1. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30lvds-ctrl: fix pkg_postrmMarcel Ziswiler
Fix pkg_postrm by renaming from previous erroneous pkg_postremove and remove /${bindir}/ which would need escaping. And while at it replace Apalis-T30 in summary with Apalis T30 and get rid of PR and empty do_compile. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30alsa-state: add asound.state for Colibri iMX7 modulesStefan Agner
2016-06-30u-boot: integrate apalis-tk1Marcel Ziswiler
2016-06-30recipes-bsp/binary-drivers: fix building cudatoolkit6.5 & opencv4tegraMarcel Ziswiler
2016-06-30tegrarcm: update to latest 1.7Marcel Ziswiler
Note: Currently only compiles -native but fails compiling for target! Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30cbootimage: update to latest 1.7Marcel Ziswiler
2016-06-30u-boot: get rid of obsolete patchesMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30u-boot, u-boot-fw-utils: update to latestStefan Agner
The upgrade is required to match to the latest update scripts which deploy the kernel and device tree into static UBI volumes. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-31u-boot: update to latest from 2015.04-toradex-nextMarcel Ziswiler
2016-03-30u-boot fsl utils: update to latest -next and add mx7Max Krummenacher
2016-03-30u-boot fsl: update to latest -nextMax Krummenacher
2016-03-30u-boot tegra: update to latest -nextMax Krummenacher
2016-03-15formfactor: add empty machconfig for colibri-imx7Colibri_iMX7_LinuxImageV2.6Alpha1_20160315Max Krummenacher
This overrides the meta-fsl-arm provided settings from machconfig. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-03-14u-boot-toradex: add i.MX 7 based modulesMax Krummenacher
This allows building U-Boot supporting Toradex Colibri iMX7 modules. Based on upstream Freescale/NXP 3.14.52_1.1.0_ga release which is based on 2015.04. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14Apalis/Colibri iMX6: drop in favour of meta-fsl-arm-extraMax Krummenacher
machine/u-boot/kernel files have been added to meta-fsl-arm-extra. Use them from there now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14Update Vybrid U-Boot to latest versionStefan Agner
2015-12-15Update all U-Boot versions to latestMax Krummenacher
2015-12-15Apalis iMX6: U-Boot: change name for IT modulesMax Krummenacher
Change the name form u-boot-it.imx to u-boot.imx-it. This prepares for the upcomming move of the i.MX 6 based modules BSP to meta-fsl-arm-extra. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-11-03Update Linux kernel and U-Boot to latest.Marcel Ziswiler
2015-10-30apalis/colibri_imx6/t30: u-boot-fw-utils: update fw_printenv/setenvMarcel Ziswiler
Introduce/update postinst code to dynamically adjust fw_env.config and fw_unlock_mmc.sh shell profile extension script to cope with our new unified eMMC layout: boot area partition 1 aka primary eMMC boot sector: with U-Boot boot loader and the U-Boot environment before the configblock at the end of that boot area partition
2015-10-30apalis/colibri_t20/t30: u-boot/fw-utils: introduce srcbranch notationMarcel Ziswiler
Introduce SRCBRANCH notation for easier switching to our -next branch.
2015-10-12Apalis iMX6: cleanup filename for V1.0 HWMax Krummenacher
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb in the kernel. The v1_0 denotes the Apalis module version, not the evaluation board version.
2015-08-13colibri-vf: update u-boot fw-utils to latestMax Krummenacher
2015-08-13colibri-vf: update u-boot to latestMax Krummenacher
2015-08-07u-boot-toradex_git: add virtual/bootloader to PROVIDESMax Krummenacher
2015-08-07u-boot: remove obsolete overridesMax Krummenacher
2015-08-07colibri-vf: use U-Boot recipe from meta-fsl-arm-extraMax Krummenacher
2015-08-07alsa-state: choose extended record volumeStefan Agner
The WM9715L AC97 codec supports two volume modes for audio capturing: basic (AC97 conform) and extended. The extended range allows smaller gain steps and a large range, hence use this mode by default.
2015-06-16base-files/u-boot-toradex-fw-utils: move MMC unlockStefan Agner
The mmc unlock function causes troubles when using Poky reference distribution since Poky uses the busybox shell: /etc/rc5.d/S09xserver-nodm: /etc/profile.d/fw_unlock_mmc.sh: line 2: syntax error: unexpected "(" This avoids X getting at all. This patch does not solve the underlying problem, but works around it by moving the script to the u-boot-toradex-fw-utils recipe, which is not installed by the Poky images by default.
2015-05-18Apalis/Colibri: update U-Boot to latestMax Krummenacher
And use 2015.04-toradex branch
2015-05-18Apalis/Colibri: update U-Boot to latest in -nextMax Krummenacher
2015-05-18Apalis iMX6 IT: u-boot: use the IT defconfig for ITMax Krummenacher
2015-05-12update to latest u-bootMax Krummenacher
2015-05-12update U-Boot and Colibri VFxx Linux to latest git revisionStefan Agner
2015-05-12update to latest u-bootMarcel Ziswiler
2015-05-12colibri_t20: fix fw_printenv/setenvMarcel Ziswiler
2015-05-12tegrarcm/cryptopp: build and use as a static libraryMax Krummenacher
We need libcryptopp only for a 32bit x86 target for tegrarcm. However linking libcryptopp dynamically and using the distro supplied 32bit compatibility libcryptopp raises an assertion: tegrarcm: secblock.h:145: CryptoPP::NullAllocator<T>::pointer CryptoPP::NullAllocator<T>::allocate(CryptoPP::NullAllocator<T>::size_type, const void*) [with T = unsigned int; CryptoPP::NullAllocator<T>::pointer = unsigned int*; CryptoPP::NullAllocator<T>::size_type = unsigned int]: Assertion `false' failed. Building only a static library with OE, (if native build forcing 32bit) fixes the issue.
2015-05-12u-boot: use latest from gitMax Krummenacher
While at it remove warning about stripped fw_printenv binary when building u-boot-toradex-fsl-fw-utils.
2015-05-12Apalis/Colibri iMX6: kernel/U-Boot update to latest in -nextMax Krummenacher
Also deploy an additional device tree supporting a Colibri iMX6 with Analog Camera Module.
2015-05-12colibri_vf: update to U-Boot 2015.04/Linux 4.0Stefan Agner
2015-05-12apalis/colibri_t20/t30: integrate latest stuffMarcel Ziswiler
2015-05-12u-boot-fw-utils: deploy fw_saveenv as symlinkMax Krummenacher
2015-05-12licenses: fix license string to known values or formatMax Krummenacher
2015-05-12u-boot-toradex-fsl-fw-utils: fix compileMax Krummenacher
cross strip tool not found without this patch.
