2018-07-27apalis-tk1: add configuration for teziMarcel Ziswiler
Modify configuration for Tezi: - Use distroboot by default - Boot from external SD cards by default - Disable USB PID from config block (otherwise recovery mode download in U-Boot stage fails) Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-07-27colibri-imx6ull: add configuration for teziStefan Agner
Modify configuration for Tezi: - Enable SDP in U-Boot - Enable FDT relocation (in-place is causing issues with FIT images) - Use distroboot by default - Boot from external SD cards by default - Disable USB PID from config block (otherwise recovery mode download in U-Boot stage fails) Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-07-27colibri_imx7: add configuration for tezi recoveryStefan Agner
Modify configuration for Tezi unified recovery mode: - Enable SDP in U-Boot - Enable FDT relocation (in-place is causing issues with FIT images) - Remove video output - Currently only for recovery (no flash/eMMC support) Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-07-27colibri_imx7_emmc: add configuration for teziStefan Agner
Modify configuration for Tezi: - Enable SDP in U-Boot - Enable FDT relocation (in-place is causing issues with FIT images) - Remove video output - Boot from external SD cards using distroboot first by default - Disable USB PID from config block (otherwise recovery mode download in U-Boot stage fails) Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-07-27colibri_imx7: add configuration for teziStefan Agner
2018-07-27mtest: disable physical memory cell test for teziStefan Agner
For faster test time shorten the alternative memory test to only do the stuck address/data line tests instead of full memory write pattern tests. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-07-27colibri_imx6: add configuration for teziStefan Agner
Modify configuration for Tezi: - Enable SDP in SPL and U-Boot - Enable FDT relocation (in-place is causing issues with FIT images) - Remove video output - Use distroboot by default - Boot from external SD cards by default - Disable USB PID from config block (otherwise recovery mode download in U-Boot stage fails) Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-07-27apalis_imx6: add configuration for teziStefan Agner
2018-07-27toradex: add easy installer configurabilityMarcel Ziswiler
Allow setting Toradex Easy Installer aka Tezi specific configuration options like not enabling SATA, directly continuing with the SDP command upon recovery, distrobooting otherwise or not storing the environment. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-07-27colibri_imx7_emmc: legacy update from external sd cardStefan Eichenberger
Use the external SD interface for legacy SD update instead of eMMC. Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-19apalis-tk1: apalis_t30: colibri_t30: display reset reasonColibri-iMX7_LXDE-Image_2.8b3.111-20180627Colibri-iMX6_LXDE-Image_2.8b3.111-20180627Colibri-iMX6ULL_LXDE-Image_2.8b3.111-20180627Colibri-VF_LXDE-Image_2.8b3.111-20180626Colibri-T30_LXDE-Image_2.8b3.111-20180627Colibri-T20_LXDE-Image_2.8b3.111-20180626Apalis-iMX6_LXDE-Image_2.8b3.111-20180626Apalis-TK1_LXDE-Image_2.8b3.111-20180626Apalis-TK1-Mainline_LXDE-Image_2.8b3.111-20180627Apalis-T30_LXDE-Image_2.8b3.111-20180626Dominik Sliwa
Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-19apalis-tk1: invoking ram_repair before powerup_cpus()Dominik Sliwa
Invoking tegra124_ram_repair() before powerup_cpus() is being invoked to avoid race-conditions if arises further. (based on downstream: fe1c9e4d523d6727afb62f03ef9fa5c0f04e7859) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-19colibri-imx6ull: set module variant depending on config blockStefan Agner
Using CPU temperature grading as a discriminator if the Wi-Fi / Bluetooth chip is populated is no longer possible due to upcoming SKUs. Set variant to -wifi only if a valid config block is present and the product id mentions a SKU with Wi-Fi / Bluetooth. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-19tdx-cfg-block: simplify i.MX 6 module detectionStefan Agner
Use CONFIG_TARGET_... at compile time to differentiate between Apalis iMX6, Colibri iMX6 and Colibri iMX6ULL. Avoid code duplication by moving question about Wi-Fi / Bluetooth before IT/non-IT decision. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-18tdx-cfg-block: add support for new Colibri iMX6ULL SKUsGerard Salvatella
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-18colibri_imx7_emmc: add fatwrite supportGerard Salvatella
Tested on Colibri iMX7 1GB aka eMMC V1.1A Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-18colibri-vf: use leveling evaluated by DDR validation toolsStefan Agner
The DDR validation tool (which is part of Processor Expert) allows to evaluate leveling parameters for CR105/CR106/CR110. Several runs have been made with Colibri VF50 and VF61 and it seems to evaluate very similar values. Use this values by default. Note: The newly evaluated parameters seem to require CTLUPD_AREF to be enabled! Note 2: The tool also evaluated 6 as a new value for PHY02/18 GATE_CFG (Coarse adjust of gate open time). However, this seems not to work in practise. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-18colibri-vf: adjust timing according to data sheetStefan Agner
Using the DDR Validation tool in Processor Expert uncovered two timing inconsistencies. Since those timings are related to the suspend mode they do not affect or change regular memory behavior. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-06ARM: vf610: ddrmc: do not write CR79 by defaultStefan Agner
The current value CTLUPD_AREF(0) is the reset value of the register, so there is no need to write a value. If needed, the register can be written using board specific CR settings. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-06ARM: vf610: ddrmc: fix CR138 preprocessor defineStefan Agner
According to the data sheet bits 10-8 are PHYDRAM_CK_EN. Fix mask to allow setting PHYDRAM_CK_EN correctly. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-06ARM: vf610: fix initialization completion detectionStefan Agner
The CR80 register has multiple interrupt bits, the code is supposed to check bit 8 but instead uses a logical and. In most cases this probably did not affect real operations since at that stage typically none of the other bits are set. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-06arm: vf610: add UART2 pinmux/clock supportStefan Agner
Add support for Vybrid's UART2 (Colibri UART_B). Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-06colibri-imx6: added nreset gpio on rebootGerard Salvatella
RGMII_RD1 pin (active high, GPIO6_IO27) is triggered on reboot during the SPL phase. This asserts (active low) nReset_Out from the PMIC. Only V1.1 and later Colibri iMX6 modules implement this in hw. Previous versions do not use this pin, so it is safe to leave it enabled at all times. Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-06cmd: ubi: print load size after establishing volume sizeStefan Agner
When using static volumes, the file size stored in the volume is determined at runtime. Currently the ubi command prints the file size specified on the console, which leads to a rather confusing series of messages: # ubi read ${fdt_addr_r} testvol Read 0 bytes from volume testvol to 82000000 No size specified -> Using max size (179924992) Make sure to print the actual size read in any case: # ubi read ${fdt_addr_r} testvol No size specified -> Using max size (179924992) Read 179924992 bytes from volume testvol to 82000000 Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-06cmd: set filesize variable in ubi readHolger Dengler
After a successful read of a UBI volume, the variable filesize is set to the number of read bytes. To boot linux with a raw initramfs/initrd, you must specify the exact size of the initramfs/initrd image in boot command. If the initramfs/inird is read from UBI volume, $filesize is required to access the number of read bytes. Example: ubi read ${loadaddr} kernelvol ubi read ${fdtaddr} dtbvol ubi read ${initrd_addr} initrdvol bootz ${loadaddr} ${initrd_addr}:${filesize} ${fdt_addr} Signed-off-by: Holger Dengler <dengler@linutronix.de> Reviewed-by: Heiko Schocher <hs@denx.de> (cherry picked from commit 985fa93e61706a78fad130b006aefa1c098145de) [backported to 2016.11] Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-06colibri-imx6ull: fix card detect GPIO of SD cardStefan Agner
Use GPIO 0 of instance GPIO5 which is used as card detect on Colibri iMX6ULL. This fixes SD card detection. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-06apalis-tk1: change usb_port_owner_info to 3 in defargsDominik Sliwa
Change usb_port_owner_info to 3 in defargs to allow for USB 3.0 SuperSpeed functionality on USBO1 in host mode. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-06colibri-imx6ull: Set the DDR RAM ASR bitSven Guggisberg
Set the ASR bit to enable auto self refresh for RAM in mode register 2. In ASR the refresh rate is dynamically adjusted to temperature which is more power efficient in suspend to RAM. Signed-off-by: Sven Guggisberg <sven.guggisberg@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-06-06tdx-cfg-block: fix off by one issueMarcel Ziswiler
Fix toradex_modules array off by one issue potentially leading to spurious printout during boot e.g. Model: Toradex V1.2A, instead of Model: Toradex UNKNOWN MODULE V1.2A. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-03-21colibri_t20: fix passing mac address via dtColibri-iMX7_LXDE-Image_2.8b2.97-20180331Colibri-iMX6_LXDE-Image_2.8b2.97-20180331Colibri-iMX6ULL_LXDE-Image_2.8b2.97-20180331Colibri-VF_LXDE-Image_2.8b2.97-20180331Colibri-T30_LXDE-Image_2.8b2.97-20180331Colibri-T20_LXDE-Image_2.8b2.97-20180331Apalis-iMX6_LXDE-Image_2.8b2.97-20180331Apalis-TK1_LXDE-Image_2.8b2.97-20180331Apalis-TK1-Mainline_LXDE-Image_2.8b2.97-20180331Apalis-T30_LXDE-Image_2.8b2.97-20180331Marcel Ziswiler
T20 uses different addresses for its EHCI controllers which I missed. Fix this. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-03-21apalis_t30/tk1/colibri_t20/t30: integrate mac address via dtMarcel Ziswiler
Use device tree to set MAC address of the Ethernet chip. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-03-21colibri_t20: integrate mtd partitions via dtMarcel Ziswiler
Use device tree to set MTD partitions of the NAND chip. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-03-21tools/env: allow equal sign as key value separationStefan Agner
Treat the first equal sign as a key/value separation too. This makes the script files compatible with mkenvimage input file format. It won't support variables with equal signs anymore, but this seems not really like a loss. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-21apalis/colibri_imx6: remove white space after string endStefan Agner
The white spaces after the zero string terminator are applied to the following environment entry. This is not what was intended. Remove the superfluous white spaces. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-21script: Make the get_default_envs.sh script working with newest u-bootLukasz Majewski
This commit fixes several issues: - Use ${OBJCOPY} if available, fallback to system default's objcopy if not present. - Extend the script to accept different build directory than current one. It is extremely handy with OE usage, where source code is separated from build. Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> [Backported to 2016.11] Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 0778e7c50ba1904943a1d6b5194c29d1fee33334)
2018-03-21colibri_vf_defconfig: enable MTD partitions via dtStefan Agner
Use device tree to set MTD partitions of the NAND chip. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-21arm: dts: imx7: add UART2/UART3Stefan Agner
This allows to change U-Boots default UART by simply changing stdout-path in the device tree. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-21apalis/colibri: switch to zimageBhuvanchandra DV
Switch to the generic compressed Kernel image type (zImage) instead of the U-Boot specific uImage format. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-21tdx-cfg-block: add new SKUsStefan Agner
2018-03-21imx: initialize and use generic timer on i.MX 6UL/ULLStefan Agner
The i.MX 6UL/ULL feature a Cortex-A7 CPU which suppor the ARM generic timer. This change makes use of the ARM generic timer in U-Boot. This is crucial to make the ARM generic timers usable in Linux since timer_init() initalizes the system counter module, which is necessary to use the generic timers CP15 registers. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-21imx: introduce CONFIG_GPT_TIMERStefan Agner
Introduce a new config symbol to select the i.MX General Purpose Timer (GPT). Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-21imx: move CONFIG_SYSCOUNTER_TIMER to KconfigStefan Agner
2018-03-21colibri-imx6ull: add MTD fixup compatible for mainline kernelsStefan Agner
In upstream Linux the GPMI NAND node of i.MX 6UL/6ULL uses "fsl,imx6q-gpmi-nand" as compatible string. Add both to make sure U-Boot fixups the MTD partitions for downstream and upstream kernels. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-20colibri_imx7: do not mux SODIMM 169 as NAND chip selectStefan Agner
The pad SAI1_RX_DATA can be used as second chip select for dual-die NAND. However, with an assembly option the pad is available as GPIO on SODIMM 169. All current version of Colibri iMX7 modules have the pad available as GPIO hence do not mux the pin so that it is available as GPIO by default. This follows a similar commit in Linux ("arm: dts: imx7: mux pad of SODIMM 169 as GPIO") Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-20apalis-tk1: add pcie_aspm=off to defargsDominik Sliwa
Disabling ASPM fixes incompatibilities with some PCIe cards Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22apalis/colibri: disable undefined instruction events in user debugColibri-iMX7_LXDE-Image_2.8b1.64-20171229Colibri-iMX6_LXDE-Image_2.8b1.64-20171229Colibri-iMX6ULL_LXDE-Image_2.8b1.64-20171229Colibri-VF_LXDE-Image_2.8b1.64-20171229Colibri-T30_LXDE-Image_2.8b1.64-20171229Colibri-T20_LXDE-Image_2.8b1.64-20171229Apalis-iMX6_LXDE-Image_2.8b1.64-20171229Apalis-TK1_LXDE-Image_2.8b1.64-20171229Apalis-TK1-Mainline_LXDE-Image_2.8b1.64-20171229Apalis-T30_LXDE-Image_2.8b1.64-20171229Stefan Agner
It turns out that OpenSSL calls undefined instructions to detect ARM capabilities at runtime (via SIGILL handler). This leads to stack traces e.g. when logging in using SSH: [ 877.464442] sshd (613): undefined instruction: pc=76ee2da8 ... Disable undefined instruction events since it is used as an autodetecion mechanism. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22colibri_imx6ull: add sensible default DFU configurationStefan Agner
Add DFU configuration which allows access to all MTD partitions. Note that DFU is mostily suited for smaller image uploads e.g. to update U-Boot but does not work well for large images such as rootfs since DFU copies the whole image in a memory buffer first. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-20apalis/colibri: enable user debug by defaultStefan Agner
Let the kernel print some debug messages when a user program crashes due to an exception. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-11-27apalis: unify configsColibri-iMX6ULL_LXDE-Image_2.7b5-20171201Apalis-TK1_LXDE-Image_2.7b5-20171201Max Krummenacher
Follow commits 59b9b3dfb and 2533000f4 which: unified the USB PID when the config block is missing added CONFIG_OF_LIBFDT_OVERLAY Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-11-27toradex apalis/colibri: set version variable for all modulesMax Krummenacher
Set the ver environment variable consistently in all modules. Move the define form include/configs into the defconfig were applicable and create a new minimal defconfig. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
