path: root/CREDITS
2008-09-05ppc44x: Unification of virtex5 pp440 boardsRicardo Ribalda Delgado
This patch provides an unificated way of handling xilinx v5 ppc440 boards. It unificates 3 different things: 1) Source code A new board called ppc440-generic has been created. This board includes a generic tlb initialization (Maps the whole memory into virtual) and defines board_pre_init, checkboard, initdram and get_sys_info weakly, so, they can be replaced by specific functions. If a new board needs to redefine any of the previous functions (specific initialization) it can create a new directory with the specific initializations needed. (see the example ml507 board). 2) Configuration file Common configurations are located under configs/xilinx-ppc440.h, this header file interpretes the xparameters file generated by EDK and configurates u-boot in correspondence. Example: if there is a Temac, allows CMD_CONFIG_NET Specific configuration are located under specific configuration file. (see the example ml507 board) 3) Makefile Some work has been done in order to not duplicate work in the Main Makefile. Please see the attached code. In order to support new boards they can be implemented in the next way: a) Simple Generic Board (90% of the time) Using EDK generates a new xparameters.h file, replace ppc440-generic/xparameters.h and run make xilinx-ppc440-generic_config && make b) Simple Boards with special u-boot parameters (9 % of the time) Create a new file under configs for it (use ml507.h as example) and change your paramaters. Create a new Makefile paragraph and compile c) Complex boards (1% of the time) Create a new folder for the board, like the ml507 Finally, it adds support for the Avnet FX30T Evaluation board, following the new generic structure: Cheap board by Avnet for evaluating the Virtex5 FX technology. This patch adds support for: - UartLite - 16MB Flash - 64MB RAM Prior using U-boot in this board, read carefully the ERRATA by Avnet to solve some memory initialization issues. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-20Merge branch 'next' of git://git.denx.de/u-boot-avr32Haavard Skinnemoen
Conflicts: MAINTAINERS
2008-08-20avr32: Add MIMC200 boardMark Jackson
The MIMC200 board is based on Atmel's NGW100 dev kit, but with an extra 8MByte FLASH and 128KByte FRAM. Signed-off-by: Mark Jackson <mpfj@mimc.co.uk> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-07-18ppc4xx: ML507 Board SupportRicardo Ribalda Delgado
The Xilinx ML507 Board is a Virtex 5 prototyping board that includes, among others: -Virtex 5 FX FPGA (With a ppc440x5 in it) -256MB of SDRAM2 -32MB of Flash -I2C Eeprom -System ACE chip -Serial ATA connectors -RS232 Level Conversors -Ethernet Transceiver This patch gives support to a standard design produced by EDK for this board: ppc440, uartlite, xilinx_int and flash - Includes Changes propossed by Stefan Roese and Michal Simek Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Acked-by: Stefan Roese <sr@denx.de>
2008-07-15mpc5xxx: Add MVBC_P board supportAndre Schwarz
The MVBC_P is a MPC5200B based camera system with Intel Gigabit ethernet controller (using e1000) and custom Altera Cyclone-II FPGA on PCI. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-10ARM: Fix for wrong patch version applied for Lyrtech SFF-SDR board (ARM926EJS)Hugo Villeneuve
ARM: Fix for incorrect version of patch applied when adding support for the Lyrtech SFF-SDR board. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com> Signed-off-by: Philip Balister, OpenSDR <philip@opensdr.com>
2008-06-10add MPC8343 based board mvBlueLYNX-M7 (doc+config)Andre Schwarz
Add MPC8343 based board mvBlueLYNX-M7. It's a single board stereo camera system. Please read doc/README.mvblm7 for details. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2008-03-31ColdFire: Added MCF5275 cpu support.Matthew Fettke
Signed-off-by: Matthew Fettke <mfettke@videon-central.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-28sh: Added support for SH7720 based board MPR2.Mark Jonas
Signed-off-by: Mark Jonas <mark.jonas@de.bosch.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-02-24Coding style cleanup. Prepare v1.3.2-rc2 release candidatev1.3.2-rc2Wolfgang Denk
2008-02-15Merge branch '080131_artila' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-14Support for Artila M-501 starter kitTimo Tuunainen
Kimmo Leppala / Sysart and Timo Tuunainen / Sysart
2008-02-14AT91CAP9 support : build integrationStelian Pop
Signed-off-by: Stelian Pop <stelian@popies.net>
2008-01-17ColdFire: MCF547x_8x - Add M5475EVB and M5485EVB supportTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
2008-01-16mpc83xx: Add the support for MPC8315ERDB boardDave Liu
The features list: - Boot from NOR Flash - DDR2 266MHz hardcoded configuration - Local bus NOR Flash R/W operation - I2C, UART, MII and RTC - eTSEC0/1 support - PCI host Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08mpc83xx: update the CREDITS and MAINTAINERSDave Liu
update the CREDITS and MAINTAINERS. Signed-off-by: Dave Liu <daveliu@freescale.com>
2007-09-23Merge git://www.denx.de/git/u-bootNobuhiro Iwamatsu
Conflicts: CREDITS
2007-08-18Coding style cleanupStefan Roese
2007-08-17ColdFire: Add M5235EVB Platform for MCF523xTsiChungLiew
2007-08-16ColdFire: Add M54455EVB for MCF5445xTsiChungLiew
2007-08-16ColdFire: Add M5253EVBE platform for MCF52x2TsiChungLiew
2007-08-15Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-14Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-10[ARM] TI DaVinci support, hopefully finalSergey Kubushyn
Add support for the following DaVinci boards: - DV_EVM - SCHMOOGIE - SONATA Changes: - Split into separate board directories - Removed changes to MTD_DEBUG (or whatever it's called) - New CONFIG_CMD party line followed - Some cosmetic fixes, cleanup etc. - Patches against the latest U-Boot tree as of now. - Fixed CONFIG_CMD_NET in net files. - Fixed CONFIG_CMD_EEPROM for schmoogie. - Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and DV_EVM. Can't check if it works on SONATA, don't have a board any more, but it at least compiles. Here is an excerpt from session log on SCHMOOGIE... U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17) DRAM: 128 MB NAND: 128 MiB In: serial Out: serial Err: serial ARM Clock : 297MHz DDR Clock : 162MHz ETH PHY : DP83848 @ 0x01 U-Boot > iprobe Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F U-Boot > ping 192.168.253.10 host 192.168.253.10 is alive U-Boot > Signed-off-by: Sergey Kubushyn <ksi@koi8.net> Acked-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com> Acked-by: Stefan Roese <sr@denx.de>
2007-08-10Add PPC4xx-HCU4 and HCU5 boards: InfrastructureNiklaus Giger
This series of patches adds support for 2 boards from Netstal Maschinen. The HCU4 has a PPC405Gpr and the HCU5 has a PPC440EPX. The HCU4 has a somehow complicated flash setup, as the booteprom is only 8 bits and the CFI 16 bits wide, which makes it impossible to use a more elegant solution. The HCU5 has only a booteprom as the whole code will be downloaded from a different board which has HD, CD-ROM, etc and where all code is stored. This is my third try. I incorporated all suggestions made by Wolfgang and Stefan. Thanks them a lot. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2007-06-18Added M5329AFEE and M5329BFEE PlatformsTsiChung Liew
Added board/freescale/m5329evb, cpu/mcf532x, drivers/net, drivers/serial, immap_5329.h, m5329.h, mcfrtc.h, include/configs/M5329EVB.h, lib_m68k/interrupts.c, and rtc/mcfrtc.c Modified CREDITS, MAKEFILE, Makefile, README, common/cmd_bdinfo.c, common/cmd_mii.c, include/asm-m68k/byteorder.h, include/asm-m68k/fec.h, include/asm-m68k/io.h, include/asm-m68k/mcftimer.h, include/asm-m68k/mcfuart.h, include/asm-m68k/ptrace.h, include/asm-m68k/u-boot.h, lib_m68k/Makefile, lib_m68k/board.c, lib_m68k/time.c, net/eth.c and rtc/Makefile Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2007-05-13sh: First support code of SuperH.Nobuhiro Iwamatsu
2007-04-04Merge with /home/wd/git/u-boot/custodian/u-boot-microblazeWolfgang Denk
2007-03-26Support for XUPV2P boardMichal Simek
Reset support BSP autoconfig support
2007-03-02mpc83xx: U-Boot support for Wind River SBC8349Paul Gortmaker
I've redone the SBC8349 support to match git-current, which incorporates all the MPC834x updates from Freescale since the 1.1.6 release, including the DDR changes. I've kept all the SBC8349 files as parallel as possible to the MPC8349EMDS ones for ease of maintenance and to allow for easy inspection of what was changed to support this board. Hence the SBC8349 U-Boot has FDT support and everything else that the MPC8349EMDS has. Fortunately the Freescale updates added support for boards using CS0, but I had to change spd_sdram.c to allow for board specific settings for the sdram_clk_cntl (it is/was hard coded to zero, and that remains the default if the board doesn't specify a value.) Hopefully this should be mergeable as-is and require no whitespace cleanups or similar, but if something doesn't measure up then let me know and I'll fix it. Thanks, Paul.
2006-11-03mpc83xx: Add support for the MPC8349E-mITXTimur Tabi
PREREQUISITE PATCHES: * This patch can only be applied after the following patches have been applied: 1) DNX#2006090742000024 "Add support for multiple I2C buses" 2) DNX#2006090742000033 "Multi-bus I2C implementation of MPC834x" 3) DNX#2006091242000041 "Additional MPC8349 support for multibus i2c" 4) DNX#2006091242000078 "Add support for variable flash memory sizes on 83xx systems" 5) DNX#2006091242000069 "Add support for Errata DDR6 on MPC 834x systems" CHANGELOG: * Add support for the Freescale MPC8349E-mITX reference design platform. The second TSEC (Vitesse 7385 switch) is not supported at this time. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-10-09Add support for EP82xxM boardsWolfgang Denk
Patch by Aaron Sells, 20 Jun 2006
2006-07-21Add support for KVME080 boardWolfgang Denk
Patch by Sangmoon Kim, 18 Aug 2005
2006-06-19Add support for wrPPMC7xx/74xx boardsHeiko Schocher
Patch from Richard Danter, 12 Aug 2005
2006-06-16Add support for gth2 boardWolfgang Denk
Patch by Thomas Lange, Aug 11 2005
2005-11-29Add support for AMCC 440SP, add support for AMCC Luan 440SP eval board.Stefan Roese
Patch by John Otken, 23 Nov 2005
2005-10-09Add support for NetSilicon NS7520 processor.Wolfgang Denk
Patch by Art Shipkowski, 12 May 2005 Cleanup.
2005-10-09Add support for AP1000 board.Wolfgang Denk
Patch by James MacAulay, 07 Oct 2005
2005-09-25Add Barco Streaming Video Card (SVC) and Sample Compress Network (SCN) boardWolfgang Denk
Patch by Marc Leeman, 04 Mar 2005
2005-09-25Add Vibren (was Accelent) PXA255 IDP SupportWolfgang Denk
Patch by Cliff Brake, 04 Feb 2005
2005-08-15Add support for Silicon Turnkey eXpress XTc (mpc87x/88x) board.Wolfgang Denk
Patch by Dan Malek and Pantelis Antoniou, 15 Aug 2005
2005-08-12Fix Murray Jensen's mail address.Wolfgang Denk
Patch by Murray Jensen, 30 Jun 2005
2005-05-19* Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the KS8695P (ARM 922 based) CPU * Patch by Steven Scholz, 19 May 2005: Add support for CONFIG_SERIAL_TAG on ARM boards
2005-04-06* Patches by Robert Whaley, 29 Nov 2004:wdenk
- update the pxa-regs.h file for PXA27x chips - add PXA27x based ADSVIX board - add support for MMC on PXA27x processors * Patch by Andrew E. Mileski, 28 Nov 2004: Fix PPC4xx SPD SDRAM detection bug * Patch by Hiroshi Ito, 26 Nov 2004: Fix logic of "test -z" and "test -n" commands
2005-04-03* Patch by Yuli Barcohen, 08 Nov 2004:wdenk
Add support for Analogue & Micro Rattler boards. Tested on Rattler8248. * Patch by Andre Renaud, 08 Nov 2004: Fix watchdog support in common/lcd.c * Patch by Marc Leeman, 05 Nov 2003: Enable all 4 PCMBRW buffers for the MPC8245 processor since the CPU bug only affects the XPC8245 processors
2005-01-09* Patch by Daniel Poirot, 10 Oct 2004:wdenk
Add support for Wind River sbc405 board * Patch by Rainer Brestan, 12 Oct 2004: Make examples/Makefile more robust
2005-01-09* Patch by Leif Lindholm, 23 Sep 2004:wdenk
add support for the AMD db1550 board * Patch by Travis Sawyer, 15 Sep 2004: Add CONFIG_SERIAL_MULTI support for ppc4xx, update README.serial_multi
2004-10-10* Patch by Michael Bendzick, 30 Aug 2004:wdenk
- Improve platform.S code for omap1510inn that detects whether code is running from SDRAM or not. Patch allows SDRAM to be configured if code is running out of SRAM at 0x20000000. * Patch by Frederick Klatt, 30 Aug 2004: Add support for the Wind River SBC8540/SBC8560 boards
