path: root/MAINTAINERS
2008-08-11MAINTAINERS: sort entriesWolfgang Denk
2008-08-11Add mpc7448hpc2 maintainer informationRoy Zang
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2008-07-15mpc5xxx: Add MVBC_P board supportAndre Schwarz
The MVBC_P is a MPC5200B based camera system with Intel Gigabit ethernet controller (using e1000) and custom Altera Cyclone-II FPGA on PCI. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-13Add last known maintainer for orphaned boards; reformat.Wolfgang Denk
2008-07-13Remove kharris@nexus-tech.net from MAINTAINERSHaavard Skinnemoen
Mail to kharris@nexus-tech.net bounces because the user doesn't exist anymore. You can't be a maintainer without a valid e-mail address, so move all boards that used to be maintained by Kyle Harris to the "orphaned" list. Currently, only PowerPC has a list of orphaned boards, so this patch creates one for ARM as well. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-06-11Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
2008-06-10add MPC8343 based board mvBlueLYNX-M7 (doc+config)Andre Schwarz
Add MPC8343 based board mvBlueLYNX-M7. It's a single board stereo camera system. Please read doc/README.mvblm7 for details. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-06-09sh: Renesas Solutions SH7763RDP board supportNobuhiro Iwamatsu
SH7763RDP has SCIF, NOR Flash, Ethernet, USB host, LCDC and MMC. In this patch, support SCIF, NOR Flash, and Ethernet. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-06-03Merge remote branch 'u-boot-at91/for-1.3.4'Wolfgang Denk
2008-06-03Merge remote branch 'u-boot-avr32/master'Wolfgang Denk
2008-05-27avr32: Add support for the ATSTK1006 boardHaavard Skinnemoen
This is a replacement for ATSTK1002 with 64MB SDRAM and NAND flash on board. It's currently in production and will be available soon. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-24Merging Stelian Pop AT91 patchesJean-Christophe PLAGNIOL-VILLARD
Merge branch 'testing-V2' Conflicts: board/atmel/at91cap9adk/Makefile Fixing copyright board/atmel/at91sam9260ek/Makefile Fixing copyright board/atmel/at91sam9260ek/u-boot.lds Delete no more needed ld script Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-21Merge branch 'quad100hd'Stefan Roese
2008-05-10AT91SAM9RLEK supportStelian Pop
This patch adds support for the AT91SAM9RL chip and the AT91SAM9RLEK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9263EK supportStelian Pop
This patch adds support for the AT91SAM9263 chip and the AT91SAM9263EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9261EK supportStelian Pop
This patch adds support for the AT91SAM9261 chip and the AT91SAM9261EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-09Mail address change, documentation modifiedVlad Lungu
Signed-off-by: Vlad Lungu <vlad.lungu@windrvier.com>
2008-05-08ppc4xx: Add the Harris QUAD100HD AMCC 405EP-based boardGary Jennejohn
Signed-off-by: Gary Jennejohn <garyj@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-28LinkStation: fix compiler warning, add a maintainerGuennadi Liakhovetski
out_8 wants a pointer to an unsigned as the first argument. Add a maintainer for Linkstation boards. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
2008-04-13Add apollon board MAINTAINERS entryKyungmin Park
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-at91Wolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
2008-04-01Add maintainership information for AT91CAP9ADK and AT91SAM9260EK boardsStelian Pop
2008-03-31ColdFire: Remove R5200 boardTsiChung Liew
This board never went into production Signed-off-by: Zachary P. Landau <zachary.landau@labxtechnologies.com> Acked-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-28sh: Add maintainer of R7780MP to MAINTAINER fileNobuhiro Iwamatsu
Update MAINTAINER entry for R7780MP. And fix maintainer's name. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-28sh: Add support Renesas Solutions R2D plus boardNobuhiro Iwamatsu
R2D plus is SH reference board used with SH7751R. This board has 266Mhz CPU, 64MB SDRAM, Cardbus, CF interface, one PCI bus, VGA, and two Ethernet controller. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-28sh: Added support for SH7720 based board MPR2.Mark Jonas
Signed-off-by: Mark Jonas <mark.jonas@de.bosch.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-28sh: Add support Renesas Solutions Migo-R boardgoda.yusuke
Migo-R is a board based on SH7722 and has may devices. In this patch, supported SCIF, NOR flash and Ethernet. Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-27ppc4xx: Add AMCC Glacier 406GT eval board supportStefan Roese
This patch adds support for the AMCC Glacier 460GT eval board. The main difference to the Canyonlands board are listed here: - 4 ethernet ports instead of 2 - no SATA port - no USB port Currently EMAC2+3 are not working. This will be fixed in a later release. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-18Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
2008-03-15Blackfin: update MAINTAINERS listMike Frysinger
Add maintainer information for the Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15ppc4xx: Add AMCC Canyonlands support (460EX) (3/3)Stefan Roese
This patch adds support for the AMCC Canyonlands 460EX evaluation board. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add 405GPr based MCU25 board. Global filesNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-02-22IDS8247: update MAINTAINER entry.Heiko Schocher
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-ixpWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-mipsWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-avr32Wolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-01-18Merge branch 'master' of git://www.denx.de/git/u-bootShinya Kuribayashi
2008-01-18AVR32: ATNGW100 board supportHaavard Skinnemoen
Add support for the ATNGW100 Network Gateway reference design, including flash, ethernet and MMC support. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-18Add AcTux board supportMichael Schwingen
Hi, The patch adds 4 boards, called AcTux-1 .. AcTux-4. This patch contains the files that contain changes for multiple boards, the board-specific files follow as separate patches. Signed-off-by: Michael Schwingen <michael@schwingen.org>
2008-01-17ColdFire: MCF547x_8x - Add M5475EVB and M5485EVB supportTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
2008-01-17ColdFire: Add MCF5227x cpu and M52277EVB support-1TsiChungLiew
2008-01-17ColdFire: Add M5373EVB platform support - 2TsiChungLiew
2008-01-17Merge branch 'master' of /home/stefan/git/u-boot/u-bootStefan Roese
2008-01-17ppc4xx: Complete DU440 board supportMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-01-17MIPS:Target support for qemu -M mipsVlad Lungu
With serial, NE2000, IDE support. Tested in big-endian mode. Memory size hard-coded to 128M for now, so don't play with the -m option. Signed-off-by: Vlad Lungu <vlad@comsys.ro>
2008-01-16Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
