path: root/api
2009-07-23api: Fix broken build on ARM.Piotr Ziecik
This patch fixes broken build introduced by commit 84bf7ca522e94ec402a1264b01971b924b7e268f (api: remove un-needed ifdef CONFIG_API already handle by the Makefile). Signed-off-by: Piotr Ziecik <kosmo@semihalf.com>
2009-06-1283xx: Replace CONFIG_MPC83XX with CONFIG_MPC83xxPeter Tyser
Use the standard lowercase "xx" capitalization that other Freescale architectures use for CPU defines to prevent confusion and errors Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-05-15api: remove un-needed ifdef CONFIG_API already handle by the MakefileJean-Christophe PLAGNIOL-VILLARD
2008-10-14api: fix type mismatchMatthias Fuchs
This patch fixes a type mismatch and thus removes a compiler warning when compiling with CONFIG_API on powerpc. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-10-14api: Fix building with CONFIG_APIMatthias Fuchs
This patch fixes building with CONFIG_API and CONFIG_USB_STORAGE. USB_MAX_STOR_DEV is defined in include/usb.h, but needed in api/api_storage.c. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-08-06Fix merge problemsStefan Roese
2008-05-14environment: cleanup prototype declarations of env functions.Wolfgang Denk
2008-05-12Revert "Change env_get_char from a global function ptr to a function."Wolfgang Denk
This reverts commit c0559be371b2a64b1a817088c3308688e2182f93 which is known to break booting from dataflash and NAND.
2008-05-12API: remove duplicate syscall checkJean-Christophe PLAGNIOL-VILLARD
2008-04-17Change env_get_char from a global function ptr to a function.Joakim Tjernlund
This avoids an early global data reference. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2008-02-14Fix remaining CONFIG_COMMANDSJean-Christophe PLAGNIOL-VILLARD
update comments Fix coding style Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-01-29API: Convert conditional building to the new scheme.Rafal Jaworowski
This fixes a build breakage with CONFIG_API enabled, which appeared after the recent changes in the U-Boot build system. Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
2008-01-10Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-01-09API for external applications.Rafal Jaworowski
This is an API for external (standalone) applications running on top of U-Boot, and is meant to be more extensible and robust than the existing jumptable mechanism. It is similar to UNIX syscall approach. See api/README for more details. Included is the demo application using this new framework (api_examples). Please note this is still an experimental feature, and is turned off by default. Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
