This commit adds initial support for the Toradex Verdin iMX8MM 2GB WB IT
V1.0A module. They are now strapped to boot from eFuses which are
factory fused to properly boot from their on-module eMMC. U-Boot
supports either booting from the on-module eMMC or may be used for
recovery purpose using the universal update utility (uuu) aka mfgtools
3.0.
Functionality wise the following is known to be working:
- eMMC, 8-bit and 4-bit MMC/SD card slots
- Gigabit Ethernet
- GPIOs
- I2C
- USB_1 peripheral: fastboot or ums
- USB_2 host: USB mass storage
To prepare the program image for eMMC fastboot using imx-mkimage and
subsequently flash it using U-Boot proceed as follows:
cd imx-mkimage/
make SOC=iMX8MM flash_evk_emmc_fastboot
load mmc 1:1 $loadaddr flash.bin
setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200
mmc dev 0 1
mmc write ${loadaddr} 0x2 ${blkcnt}
To prepare the program image for use with USB recovery aka serial
downloader using imx-mkimage and subsequently download using uuu
with an uuu.auto script proceed as follows:
cd imx-mkimage/
uuu_version 1.3.34
SDP: boot -f flash.bin
CFG: SDPU: -vid 0x0525 -pid 0xb4a4
SDPU: delay 1000
SDPU: write -f flash.bin -offset 0x57c00
SDPU: jump
Fusing i.MX 8MM SoC and configuring eMMC for fastboot (already done
during manufacturing):
fuse prog 1 3 0x100020d6 (BT_FUSE_SEL, eMMC boot, SD1, fast boot, 4-bit DDR, high speed, 1.8V)
fuse prog 2 2 0x00000001 (enable boot ack)
mmc bootbus 0 1 0 2 (4-bit, reset bus width, DDR)
mmc partconf 0 1 1 0 (booting from boot area partition 1, send acknowledge)
SD manufaccture boot:
SD manufacture boot only works as long as the module is un-fused and
SD_1_PWR_EN is bypassed on the carrier board.
cd imx-mkimage/
sudo dd if=iMX8M/flash.bin of=/dev/mmcblk0 bs=1024 seek=33
Initial board support for Apalis iMX8QXP using a copy of Colibri iMX8QXP.
Initial board support for Colibri iMX8QXP using a copy of Apalis iMX8.
(cherry picked from commit 62f0f03e1acb4bb6b0fcca8d4e9bd4d2df04ad33)
(cherry picked from commit be14c3ea1850e2614883c86b62fd1c3a1828eac2)
(cherry picked from commit aa830cb6a7c953ce85232b2ae951543ab1060948)
(cherry picked from commit f6c37cdf31633a541078d0813ab4f59f6b80babb)
(cherry picked from commit ae70d02213beabcd60853f655e2ff9849375c45c)
(cherry picked from commit ba629689c627a571d5902a1c50fe9927424b45c6)
Add DDR3 init codes, board codes, defconfig and DTS into u-boot.
Basic modules are ready: SD, UART, I2C, USB host and NAND.
There is a FPGA on this board. It controls WDOG_B, and ENET PHY RESET.
So reset and ethernet won't work at default.
Signed-off-by: Ye Li <ye.li@nxp.com>
Acked-by: Peng Fan <peng.fan@nxp.com>
add config for emmc, nand and qspi boot
Signed-off-by: Robby Cai <robby.cai@nxp.com>
Add i.MX6ULZ support. the i.MX6ULZ is SW compatible
with i.MX6ULL. so most code of i.MX6ULL can be reused
by i.MX6ULZ.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
Add DDR4 init codes, u-boot dtb and defconfig to support DDR4 EVK.
The DDR4 EVK removed eMMC and Flexspi, but use NAND instead. Current
codes support to boot from SD and enable NAND access in regular u-boot.
Add new dts, config and defconfig file for DX DDR3 ARM2 board. Since
it does not have USB3.0 and SD, disable them in DTS and header file. Also move
gpio expander to i2c1 according with its schematic.
In defconfig, fastboot is default enabled due to we need uuu to program
eMMC.
(cherry picked from commit e5b822615a5aa2fadb481002c286f35d996999f8)
Add a DTS file for iMX8MM DDR4 validation board whose design is similar
as iMX8MM EVK.
(cherry picked from commit abe2268c73e409f8faafc80a182203f2fa6e39c2)
We are targeting let uboot loading images from emmc to boot android.
Currently only emmc1 is enabled, so other devices are disabled.
Also change memory layout according to VM layout. The memory layout
needs to be samesize as what you configured in as "memory = "3584"".
Add a new dts dedicated for this kind uboot, add a new defconfig
to select CONFIG_XEN/CONFIG_XEN_DEBUG_SERIAL, deselect CONFIG_DM_SERIAL,
select CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK, and disable some devices
compared with imx8qm_mek_androidauto_defconfig.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit a4e932cae433b9d2e1cff6a94b12e4abcac45543)
Porting the imx8m-phanbell android things board support from v2017.03
Signed-off-by: Haoran.Wang <elven.wang@nxp.com>
Add DTS files to support iMX6Q/DL DDR3/LPDDR2 ARM2 and iMX6Q POP LPDDR2 ARM2 boards.
Add DTS files to support iMX7ULP 10x10 ARM2 and 14x14 ARM2 boards.
ARM2
Add DTS files to support iMX7D 19x19 LPDDR3, DDR3 and LPDDR2 ARM2 boards.
Add DTS files to support iMX7D 12x12 LPDDR3 and DDR3 ARM2 boards.
Due to pin conflicts, need specified DTS for SPINOR, QSPI on LPDDR3
ARM2.
Add DTS files to support iMX6SLL 14x14 LPDDR3/LPDDR2 ARM2.
Due to pin conflicts, need specified DTS for SPINOR enabled.
Add DTS files to support iMX6ULL 14x14 DDR3 ARM2.
Due to pin conflicts, need specified DTS for eMMC, EPDC, NAND/EIMNOR and tsc enabled.
Add DTS files to support iMX6UL 14x14 DDR3 ARM2 and 14x14 LPDDR2 ARM2.
Due to pin conflicts, need specified DTS for eMMC and NAND/EIMNOR enabled.
Add DTS files to support iMX6SX 19x19 ARM2. Due to pin conflicts,
need specified DTS for NAND/EIMNOR enabled.
Add DTS file for the iMX6SX 14x14 ARM2 from v2017.03
Add DTS files to support iMX6SX 17x17 ARM2. Due to pin conflicts,
need specified DTS for SPI nor enabled and NAND/EIMNOR enabled.
Add i.MX8MM EVK board support
LPDDR4 code is still keep in old coding style to ease updating
if there is no code released.
dts is synced from kernel with sd2 regulator start up delay and off on
delay added.
(cherry picked from commit 01b3f229b188e28b0887c0b32f66e939a50d3a69)
Ported the DTS file from u-boot v2017.03 for i.MX8QXP MEK board.
Ported the DTS file from u-boot v2017.03 for i.MX8QM MEK board.
Ported the DTS file from u-boot v2017.03 for i.MX8QXP LPDDR4 ARM2
board and i.MX8QXP DDR3 ARM2 board.
Ported the DTS files from u-boot v2017.03 for i.MX8QM LPDDR4 ARM2
board and i.MX8QM DDR4 ARM2 board.
Add board codes, configurations, DTS and DDR initialization codes for the
DDR3L and DDR4 ARM2 boards.
Supported modules
- DDR3L ARM2: Two RANK DDR3L, QSPI B, eMMC/SD, RMII ENET, UART.
- DDR4 ARM2: Two RANK DDR4, SD, NAND, RGMII ENET, UART.
NAND read/write/erase is ok in u-boot, NAND SPL boot will be tested later
when tool is ready.
Update the DTSi and add imx8mq-evk DTS file from v2017.03.
The MMC alias are removed to fix MMC device index problem.
Add build configuration and DTS file to enable eMMC for eMMC reworked
EVK board.
Because the eMMC DTS file has QSPI node disabled, so we change to use
non-DM QSPI driver.
(cherry picked from commit 9ae0e03eb829f694d26caec22f91d1f0fdba980d)
Porting the QSPI flash board support from v2016.03, and convert to use
DM QSPI driver.
Since we need to support QSPI at default in u-boot, change the default
DTS file to qspi enabled DTS.
(cherry picked from commit 41895cd598be6c4a64fc4fec521120e4962abc28)
Update the DTS files for 14x14 EVK and 9x9 EVK to align with
v2017.03. The MMC alias are removed for v2018.03
Update imx6ul.dtsi file to align with kernel
(commit f3834c73366f985fef6c1fdaaa129dfceb6151cb)
Remove the MMC alias due DM MMC will used as device index.
Add the DTS files for 14x14 EVK, 9x9 EVK, etc.
Porting the the imx7d dtsi, dts files and binding files from kernel
(f3834c73366f985fef6c1fdaaa129dfceb6151cb)
New dts files are added to support GPMI-WEIM, QSPI, RevA boards.
Changes in DTS and DTSi:
1. Add USB alias
2. Modify the SPI alias for qspi
3. Disable USDHC2 since it is for SDIO
4. Add i2c force idle support pins
5. Add LPSR pinfunc file
6. Removed mmc alias. So that device id in DM-MMC is aligned with Non-DM MMC.
Add epdc support from v2016.03.
Add a epdc specified DTS file for using epdc
(cherry picked from commit ab2f9e136f5da034a8335dc8ca276a54367132e8)
v2017.03
Port the DTS and relevent binding files from v2017.03 for i.MX6DQ/DQP/DL/S
Sabreauto and SabreSD boards.
Removed the MMC alias from v2017.03, since the MMC will use it as device index when
DM MMC is enabled. This causes mismatch with Non-DM MMC case.
Add R8A77965 M3N Salvator-XS development kit support. This kit is
similar to the other Salvator-X(S) ones, except is has M3N SoC on
it.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Add support for a new boards from devboards.de , the DBM-SoC1 .
This board has one ethernet port, one USB OTG port and USB UART.
Engicam Is.IoT has eMMC and NAND cpu modules where MMC
is common for both, so remove explicit mmc defconfig.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
i.CoreM6 1.5 is an another i.CoreM6 QDL cpu modules which can be connected
to EDIMM starter kit design with eMMC and MIPI-CSI interfaces suitable for
Android and video capture application.
notable features:
CPU NXP i.MX6 S/DL/D/Q, Up to 4 x Cortex-A9@800MHz
Memory Up to 2 GB DDR3-1066
Video Interfaces Up to 1 Parallel Up to 2 LVDS HDMI 1.4
port 8 bit CSI INPUT MIPI-CSI INPUT
1 x 10/100 Ethernet interface, 2 x USB, 1 x PCIe, 1 x I2S etc
This patch adds support for Quad/Dual and DualLite/Solo SOM's on
MIPI starter kit with boot from SD and eMMC.
Xilinx changes for v2018.03
- Several Kconfig fixes (also moving configs to defconfigs)
- Some DTS updates
- ZynqMP psu rework based on Zynq concept
- Add low level initialization for zc770 and zcu102
- Add support for Zynq zc770 x16 nand configuration
- Add mini nand/emmc ZynqMP targets
- Some arasan nand changes
This patch adds new target which is called as mini configuration
with only emmc functionality and other required basic features enabled.
This will be used to run in system with small footprint and needs
emmc support.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
with only nand functionality and other required basic features enabled.
nand support.
This patch adds support for the PDU001 board.
Signed-off-by: Felix Brack <fb@ltec.ch>
This DT file comes from kernel v4.15, this board offers :
_ STM32F429NIH6 microcontroller
_ 4.3” color TFT LCD with resistive touchscreen (480 x 272 pixels)
_ Six 5 V power supply options:
Power jack
ST-LINK/V2 USB connector
User USB HS connector
User USB FS1 connector
User USB FS2 connector
Daughterboard
_ SAI Audio DAC, stereo audio jack which supports headset with
microphone
_ Stereo digital microphone, audio terminal connector used to connect
external speakers
_ 2 GBytes (or more) SDIO interface MicroSD card
_ RF EEPROM on I2 C compatible serial interface
_ RS-232 communication
_ IrDA transceiver
_ JTAG/SWD and ETM trace debug support, ST-LINK/V2 embedded
_ IEEE-802.3-2002 compliant Ethernet connector
_ Camera module
_ 8M x 32-bit SDRAM, 1M x 16-bit SRAM and 8M x 16-bit NOR Flash
_ Joystick with 4-directional control and selector
_ Reset, Wakeup and Tamper buttons
_ 4 color user LEDs
_ Extension connectors & memory connectors for daughterboard or
wrapping board
_ USB OTG HS and FS with Micro-AB connectors
_ RTC with backup battery
_ CAN2.0A/B compliant connection
_ Potentiometer
_ Motor control connector
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
This commit adds OMAP3 BeagleBoard devicetree files from
Linux v4.15-rc5. This includes standard OMAP34XX board revisions as
well as the 'xM' which is OMAP36XX.
Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
Add initial dts support for am574x-idk
This commit adds support for 96Boards Dragonboard820C.
The board is based on APQ8086 Qualcomm Soc, complying with the
96Boards specification.
Features
- 4x Kyro CPU (64 bit) up to 2.15GHz
- USB2.0
- USB3.0
- ISP
- Qualcomm Hexagon DSP
- SD 3.0 (UHS-I)
- UFS 2.0
- Qualcomm Adreno 530 GPU
- GPS
- BT 4.2
- Wi-Fi 2.4GHz, 5GHz (802.11ac)
- PCIe 2.0
- MIPI-CSI, MIPI-DSI
- I2S
U-Boot boots chained from LK (LK implements the fastboot protocol) in
64-bit mode.
For detailed build instructions see readme.txt in the board directory.
Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
