Allow reading recovery mode (RCM) boot type from the boot information
table (BIT) written by the boot ROM (BR) to the IRAM.
Tegra124 moved the CSITE block's base address. Fix U-Boot to use
the correct address.
Signed-off-by: Tom Warren <twarren@nvidia.com>
These headers define the Tegra124 hardware. Add them to the usual
place.
Add Tegra124 chip ID/SKU ID definitions to common headers.
There's no real HW change on Tegra124 for 90% of the toys, so it might
make sense for a future patch to unify some of the content of these
files in a common location.
Tested-by: Thierry Reding <treding@nvidia.com>
Add the Tegra30 SKU b1 and treat it like other Tegra30 chips.
Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de>
Reviewed-by: Julian Scheel <julian.scheel@avionic-design.de>
[trini: Fixup common/cmd_io.c]
Make U-Boot aware of the Tegra20 SKU 7, and treat it identically
to any other Tegra20.
My Whistler board has a SoC with this SKU.
Make U-Boot aware of the Tegra114 SKU 1, and treat it identically
to any other Tegra114.
This value is used on (at least some) Dalmore boards with a production
rather than engineering chip. Such boards are in the hands of some
partners who want to use upstream U-Boot.
Make U-Boot aware of the T33 SKU of Tegra30, and treat it identically
to any other Tegra30.
An alternative would be to simply remove the SKU checking from
tegra_get_chip_type(); most use of the value most likely simply wants
to know the current chip, not the specific SKU. Or, the function could
be split into separate tegra_get_chip() and tegra_get_sku() for the
cases where differentiation really is required.
I wonder whether tegra_get_chip_type() should printf() whenever any
unkown chip/SKU is found, although perhaps the function is called so
early that the printf() wouldn't actually make it to the UART anyway.
Common Tegra files are in arch-tegra, shared between T20/T30/T114.
Tegra114-specific headers are in arch-tegra114. Note that some of
these will be filled in as more T114 support is added (drivers,
WB/LP0 support, etc.).
Add I/O addresses of SPI SLINK controllers 1-6
Signed-off-by: Allen Martin <amartin@nvidia.com>
Common Tegra files are in arch-tegra, shared between T20 and T30.
Tegra30-specific headers are in arch-tegra30. Note that some of
these will be filled in as more T30 support is added (drivers,
WB/LP0 support, etc.). A couple of Tegra20 files were changed
to support common headers in arch-tegra, also.
The move is pretty straight-forward. ap20.h and tegra20.h were renamed to ap.h and tegra.h.
Some files remain in arch-tegra20 but 'include' a file in 'arch-tegra' with #defines & structs
that will be common between T20 and T30 HW. HW-specific #defines, etc. stay in the 'arch-tegra20'
'root' file.
All boards build OK w/MAKEALL -s tegra20. Checkpatch.pl runs clean. Seaboard works OK.
