path: root/board/esd/cpci440/u-boot.lds
2007-12-27Remove CPCI440 boardMatthias Fuchs
This board never left prototyping state and it became a millstone round my neck. So remove it. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-10-31ppc4xx: Rework of 4xx serial driver (2)Stefan Roese
Change all linker scripts to reference the changed driver name 4xx_uart.o. Note: In most cased all these explicit referencing of these object files in the linker scripts is not neccessary. Only for manually embedded environment into the U-Boot image, which is not done is most cases. Signed-off-by: Stefan Roese <sr@denx.de>
2005-08-16Merged 405gp_enet.c and 440gx_enet.c to generic 4xx_enet.cStefan Roese
now handling all 4xx cpu's. Patch by Stefan Roese, 16 Aug 2005
2004-12-16CPCI440 board updatestroese
2002-08-06Initial revisionwdenk
