path: root/board/nx823/nx823.c
2014-04-18powerpc: remove NX823 board supportMasahiro Yamada
Enough time has passed since this board was moved to Orphan. Remove. - Remove board/nx823/* - Remove include/configs/NX823.h - Clean-up ifdef(CONFIG_NX823) - Move the entry from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2009-03-27ppc: cleanup compiler errors/warningsHeiko Schocher
Current u-boot top of tree builds with warnings/errors for the following boards: ads5121 cpci5200 mecp5200 v38b IAD210 MBX MBX860T NX823 RPXClassic debris PN62 following patch solves this. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2009-03-20nx823: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. For the nx823, the serial number is moved out of load_sernum_ethaddr() and into misc_init_r() as is the env setup. This lets us kill off the former function in the process. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2002-08-26Initial revisionwdenk
